07-14-2014, 13:29 | #1 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1860261 Status: Offline Thanks Meter: 0 | s4 i9505 buzzer doesn't work after water The buzzer doesn't work after clean. I checked the charge dock, I have tried with another but not sound. Some solution? Thank you. |
07-17-2014, 11:50 | #4 (permalink) |
Member: 1860261 Status: Offline Thanks Meter: 0 | I tried that you tell me but buzzer doesn't work. At the begging, I checked with tester. The ways was broken. Then, I jumped and checked but buzzer doesn't work. Some idea? I attach a pic. [IMG][/IMG] |
07-17-2014, 13:50 | #5 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | s4 i9505 buzzer doesn't work after water samsung gt-i9505 speaker ringer solution try to replace it with a new speaker rehot ic audio codec (1) and check its speaker lines to pin speaker (charging port flex with mic) = (2) see the image below: only thank button |
The Following 3 Users Say Thank You to d-Artigo For This Useful Post: |
10-09-2015, 23:18 | #6 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2470605 Status: Offline Thanks Meter: 0 | Samsung S4 (I9505) microphone problem Hello, Can someone please heeeelp me, I have a Samsung s4 I9505 that I bought with a problem: When I call someone I can hear perfectly but the other person hears a crackling sound and almost no sound but ONLY IN NORMAL CALL mode, when in SPEAKER it seems to work just fine, also with the headset the crackling sound persists. The problem also persists in any app like viber, watsapp, voice recorder.. Things I have tried: Restarting, factory reset Different firmware like Kitkat 4.4 and Lollipop 5.01 Changing the charge dock with the microphone Is there another microphone that is activated while on speaker mode than on normal call or what is the difference between normal call and speaker mode? |
