01-05-2016, 00:16 | #5 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2510799 Status: Offline Thanks Meter: 0 | What do you mean by reheating? Hold a soldering iron on to it? Or re solder each of the pin connections? Can you clarify what needs to be done with the lines marked? Check the continuity of these connections? What did you do if there was a failed connection? |
05-05-2017, 21:13 | #14 (permalink) |
Junior Member Join Date: May 2017
Member: 2713824 Status: Offline Thanks Meter: 1 | Hello! I reflow 20794S1A chip and s4 still working! (12 hours already!) The earlier problem was a "no sim card" or reboot the phone. it may work! We will see! Thanks for solution! |
The Following User Says Thank You to batic For This Useful Post: |
08-16-2017, 16:13 | #15 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2745890 Status: Offline Thanks Meter: 0 | Hey Guys, got the same problem here with my S4, and I'd like to try to reheat the IC. Did you use a normal hairdryer for that? Do the surrounding components have to be protected from the heat? For example with using a nozzle with a small outlet? Thanks in advance. |
