Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 12-21-2013, 13:35   #1 (permalink)
Member: 880191
Thanks Meter: 6
s5570 charging problem
When you plug the charger shows a yellow mark on the battery so
Old 12-21-2013, 15:17   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,628
samsung gt-S5570 charging problem
1. try changing its charging connectors
2. check his charging path
if the second item above well ... try to replace Q601
if it is still as before rehot or replace U609
see the image below:
only thank button
Old 12-21-2013, 15:42   #3 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
only thank button
1st replace battry than .......................
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Old 04-20-2014, 11:41   #4 (permalink)
knives143's Avatar
Member: 407557
Thanks Meter: 102
Check BSI lines got the same issue and checking for schematics 80% possibility it is on the bsi lines
Page generated in 0.20487 seconds with 9 queries
