Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 05-04-2013, 07:36   #1 (permalink)
Member: 16142
Thanks Meter: 21
samsung i9100 auto power on
hi
samsung i9100 when power off , mobile power of again auto power on with out press power button. any solution please....
Old 05-04-2013, 08:13   #2 (permalink)
Member: 1899191
Sonork: 100.1625109
Thanks Meter: 136
try to flash with latest firmware and if it show same problm its meansi its hard problm on terminale
Old 05-04-2013, 08:23   #3 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
change on off swich
100% problem soolf
Old 05-24-2013, 08:41   #4 (permalink)
Registered User
Member: 1901604
Sonork: 100.1622736
Thanks Meter: 72
try to harsreset your phone vol - press home buttun and power key may b your problem solvd.....................
Old 05-24-2013, 09:00   #5 (permalink)
Member: 1892801
Thanks Meter: 10
dear, change the usb soket my be solve your problam
Old 03-25-2014, 09:15   #6 (permalink)
inamullah790000's Avatar
Member: 1985156
Sonork: 100.1652265
Thanks Meter: 313
not working update 4.1.2 some problem chang power button charging socket not working
Old 03-25-2014, 11:57   #7 (permalink)
Member: 2127758
Thanks Meter: 26
This solve 100%
Fix almost 90 auto power on changing all the flat "usb + mic + antenna connector"
Old 04-22-2014, 00:31   #8 (permalink)
Member: 220595
Thanks Meter: 355
Did someone discovered how to fix this flex?
I need to fix it, not replace it, and I can confirm it is the flex, I tried a different flex and phone will not power on by itself.
after replacing the original flex the phone keeps powering on.
I cleaned the flex very well, including the usb socket.
I suspect on a black small IC in the flex, near to the usb socket, what is this IC's function?
Old 04-22-2014, 13:17   #9 (permalink)
Member: 2127758
Thanks Meter: 26
replace the usb socket and you will fix the flex...
Page generated in 0.15812 seconds with 8 queries
