03-06-2018, 12:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2643514 Status: Offline Thanks Meter: 28 | S6 Edge Keys Not Working Sent from my iPhone using Tapatalk |
03-06-2018, 18:07 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 176003 Status: Offline Sonork: bb pin 27883543 Thanks Meter: 74 | what have you done so far to the handset? have you tried to reflow the pcb as i see the handset was dropped. please reflow and try a software update. then post reply if it does not work |
03-06-2018, 18:08 | #3 (permalink) | |
Member: 2643514 Status: Offline Thanks Meter: 28 | Quote:
hi it was water damaged. which ic i should reflow? Sent from my iPhone using Tapatalk | |
03-06-2018, 18:34 | #4 (permalink) |
Member: 176003 Status: Offline Sonork: bb pin 27883543 Thanks Meter: 74 | i would normaly check where it was coroded , i would clean and reflow. however asses the componants near the charging flex conector. reflow else test the handset with another flex |
03-06-2018, 18:34 | #5 (permalink) |
03-06-2018, 20:28 | #6 (permalink) | |
i need to know what lines power the keys or what ic is responsible. they forum is not being useful recently as the experienced members dnt even bother helping at all Sent from my iPhone using Tapatalk | |
03-06-2018, 20:31 | #7 (permalink) |
Freak Poster Join Date: May 2008
Member: 777576 Status: Offline Thanks Meter: 32 | if the display connector is clean and has NO corrosions, then it is pretty obvious that you have an broken line for the soft keys, down on the display, left and under the home button. if so, you will not be able to get it to work again. the best way to check if you have a faulty mainboard or display unit, would be to take another s6 edge mainboard to test this display unit with it... |
03-06-2018, 20:40 | #8 (permalink) | |
the flex cable looks like this. it’s got the touch buttons on the flex. what’s it got anything to do with display??? Sent from my iPhone using Tapatalk | |
03-06-2018, 21:55 | #10 (permalink) | |
oh right. now i understand. the flex cable pads are only for light not for touch! normally cables like these have touch build in to them. ie s6 Sent from my iPhone using Tapatalk | |
03-06-2018, 22:03 | #11 (permalink) |
Member: 777576 Status: Offline Thanks Meter: 32 | restart the phone and see if the soft key lights will turn on for few moments. if yes, then the U7002 is OK and you have definetely broken soft key lines inside of display, so when you press the soft keys, the light can and will not turn on, because it is like you don't touch the keys at all ;-) understood? |
03-06-2018, 22:05 | #12 (permalink) | |
when i restart there is no light!!! Sent from my iPhone using Tapatalk | |
03-06-2018, 22:12 | #13 (permalink) |
Member: 777576 Status: Offline Thanks Meter: 32 | then you will have to check the mainboard very carefully under the microscope and search for liquid damages or you maybe can try to get another s6 edge mainboard to test if mainboard or display is faulty. |
03-06-2018, 22:27 | #14 (permalink) | |
i have a lab setup microscope and eveything but i can’t seem to find any schematics that would explain how those touch buttons work and which ic supplies them power and power ways! Sent from my iPhone using Tapatalk | |
