04-23-2017, 17:33 | #16 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | 1. U7007 Wireless Charger IC 2. U7026 IF PMIC 3. U7002 AP PMIC 4. U3000 CP PMIC What i can say, only one - the Great Job And what do you have?....Nothing? I'm suppose - Дырку от бублика..... OK, now a little bit of theory "How to repair dead phone with oscilloscope" Why oscilloscope, you can ask? Look. The cell-phone is a classic MPS (micro processor system). It contains CPU, memory, data BUS, address BUS, timing oscillator and some peripherys. This MPS working when timing clock is present. If no timing - MPS is dead. In case of cell-phone, it contains MPS and periphery (keyboard/touch, transceiver, SIM reader and so on). In all cell-phones present two important clocks - 1. So called "sleep clock" - 32,768 kHz. It is the same in all phones and other electronic equipment. 2. So called "Main system clock" - 24 MHz for Samsung, 38 MHz for Nokia and so on (depends from model). What is "sleep clock" provide? When this clock is present, CPU can see that you press POWER button on the phone. What is next? CPU give command to PMIC to turn on phone. If the "Main system clock" is present, CPU can load the software to operating memory and the main phone OS is start. So you can see - no oscilloscope, no real opportunity to repair dead phone. BR. P.S. You can download the software "Sound card oscilloscope", you be able to check 32,768 kHz - www.UO5OQ.com GSM Форум |
The Following 6 Users Say Thank You to KorAll For This Useful Post: |
05-01-2017, 18:24 | #18 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | hi KorAll thanks for very useful mini lesson but i've a question .. i've alreadi replaced same series of components of Hum e also my problem is not solved. I've replaced OSC5000 problem not solve , so even is try to ceck with oscilloscope what changes.. I admit to have replaced the whole set of components that have to do with the power line but I'm convinced that the problem is the CPU .. it's already the third phone I try to fix with the same problem .. thank you |
05-01-2017, 19:17 | #19 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | Quote:
will u please share u rehot or something else ? | |
05-01-2017, 20:50 | #21 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | oh yes u r right it means u still not solve did u try to replace charging regulator near big audio ic because i only miss this ic |
05-01-2017, 23:12 | #23 (permalink) |
Freak Poster Join Date: May 2010 Location: in your mind
Member: 1315205 Status: Offline Thanks Meter: 21 | s6 edge no power water damaged Hi I have one dead (water) after cleaning remove shorted Now it take 0,32 in charge and 0,38 when I press pwr How much it take in working one? |
05-02-2017, 22:07 | #24 (permalink) | |
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Quote:
You must check Vbat at C7005, C7006 (top side of picture). At the right sight of pic. you must check: NPOWER - power for AP. AP_RST_IN_N - reset signal for AP. AP_PMIC_IRQ - interruption signal. PMIC_CLK_32K - signal 32,768 kHz at TP7003 (buffer output). CP_CLK_32K - signal 32,768 kHz to CP. AP_CLK_32K - signal 32,768 kHz to AP at TP7002. All this signals must be present, when you press and hold power button (SW_ON must present at the left side of pic.). @HUM Hi, dear. I'm not conjecture the cause of damage. I have measure voltages on all IC's, check all signals, check all ways and some other. Only after that i shall decide - what to do... @7ope Sleep current 0,2 ~ 7 mA (milliampere) Charger spec (5.0V - 2A, 9.0V - 1,67A) adaptive. | |
The Following 7 Users Say Thank You to KorAll For This Useful Post: |
05-03-2017, 12:50 | #25 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | Hi KorAll respect ! a great help ..solutions not already ready but just to reason , stay with us I recommend, real technicians have remained few and I just have to learn..All this is a next step ! anyway thank you dear , coming soon i will try ceck TP on schematic |
The Following 6 Users Say Thank You to orx For This Useful Post: |
08-22-2017, 17:10 | #27 (permalink) | |
Junior Member Join Date: Aug 2017
Member: 2750087 Status: Offline Thanks Meter: 0 | Quote:
Hi,you have come to a solution?? Verzonden vanaf mijn iPhone met Tapatalk | |
