07-27-2016, 06:30 | #1 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2603643 Status: Offline Thanks Meter: 1 | S6 Edge SM-G925F Random Reboot I bought an S6 Edge with a broken screen to replace it an use it as my own mobile. Unfortunately the device reboots randomly. It was possible to install the latest OTA Update, but it keeps rebooting after a short time of use. Can't even go to Play Store,.... Sometime it's in a bootloop just at the first Logo. It even reboots in Receovery! =( The cracked screen must be caused by a quite heavy impact. It also gets pretty warm. First i tought, it may be a battery problem, but same problems while charging. Any ideas, where to start? Cheers! |
07-27-2016, 09:48 | #4 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 176003 Status: Offline Sonork: bb pin 27883543 Thanks Meter: 74 | Could be open circuit on main board try reheating the pcb and testing it afterwards Sent from my GT-I9505 using Tapatalk |
The Following User Says Thank You to clebo For This Useful Post: |
08-02-2016, 07:34 | #7 (permalink) |
Member: 2603643 Status: Offline Thanks Meter: 1 | Did a Reflash with Smart Switch. Flashing the device didn't made any problems. First boot ==> after 15 sec. reboot of the device! =( That's strange. As flashing works fine i think its no problem of a certain component. I'll try reheat the mainboard. Whats your suggestion? |
08-03-2016, 09:34 | #9 (permalink) | |
Member: 2603643 Status: Offline Thanks Meter: 1 | Quote:
but, thanks anyway | |
The Following User Says Thank You to jackmcleassig86 For This Useful Post: |
08-03-2016, 10:05 | #10 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | yes but like for i9300 , i9500/9505 etc suffering from the same problem, they were often in bootloop other times on and off .. However a check would do, good luck and post if you solve. |
