03-21-2016, 22:53 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | You can't always use this method not all cases have same solutions like removing WiFi ic it did work for a phome but not necessary to work with you as well Please use this steps 1-Clean your phone motherboard and check 2 -connect your phone to power supply and check for heating ic 3-if no ic appear to be heating reduse voltage to 1.5v and start to make it hight but you need is the hight amperage you can get that will make ic heating and will show you where you can start 4-if no ic is heating After using step 3 start to heat /move /elivate ic / clean /reball ic / fixe ic to her pleace or change each ic one by one 5-if you find a heating ic after step 2 hrat/move/elivate ic/clean /reball ic /fixe same ic again if not problem have been solved change ic Only thanks botton |
The Following User Says Thank You to habibboxes For This Useful Post: |
