samaung D500 dear friends when I am connecting battery to the phone (D500) its show me USB Charging Not Available can some one help to sort out this problem. |
you mean even the battery full ,also show this information for you , did you change a new battery try ?? BR., Denis |
Are you using standard charger m8?? |
post ur question clearly here |
look here and try :( :mad: :confused: :D :cool: :rolleyes: :) |
1. you need to use correct D500 cable 2. connect without battery 3. press unlock 4. press info to see the key M number 5. disconnect cable, insert sim, connect battery, turn phone on and enter key M number. Phone should now be unlocked Quote:
Hi, never seen such stupid answers on a clear qeustion. regards Sjakie |
help me i have d500 mic not worrking i need S O L U T I O N and z 500 insert sim thanks to all.hossam |
d500 not entring in tat mode. which solution for ths |
same problem d500 usb charging not available Quote:
has anyone got a sensible answer to this question i have a d500 with same problem :confused: when i plug a charger into the phone it charges for about 10 seconds then displays usb charging not available any help would be good but i dont need to unlock the phone lol:p |
world OF COMM MANCHESTER HAS THE SOLUTIONS |
well ?? well what is the solution then ?? YOU MUST BRING TO WORLD OF COMM ???????? ok so safwanp will just pop to your shop in manchester when he lives in india :rolleyes: u tool its a forum to share info what is the point in that reply m8 ??? or are u just trying to advertise your shop m8 ?? regards geeza |
