09-25-2012, 01:07 | #1 (permalink) |
Insane Poster Join Date: Feb 2012
Member: 1717728 Status: Offline Sonork: 100.1612656 Thanks Meter: 29 | Samsung 3303k Automatic Charge Done:[Complete Procedure Inside] Unit: Samsung 3303k Problem: Automatic Charge Or auto connected PC. Kahit hindi naka saksak ang charger/Cable to pc! Suspect Problem: USB Port Action and Procedure: step #1. Test The Phone Using Tester To check If shorted or not. step #2. Dismantled the Phone And Check USB port If Damage Or Not/ Clean Usb port First Step #3. Temporary Disable The USB Connection like This. This image has been resized. Click this bar to view the full image. The original image is sized 1024x768. And Connect The Battery If Problem Solve Or not: Here: Still Problem!!! Proceed the Another Solution: Here: And Connect The Battery again and Pray:Lord *** i hope It will Done!!! And Big Smile Hop it Will Help |
09-25-2012, 04:57 | #5 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Romania Age: 48
Member: 59869 Status: Offline Thanks Meter: 132 | For the two n00bs which are thanking for nothing, here is the missing image (actually the most important one, where he shows Vbat pin from usb connector cutted down): Now you can call it "Complete procedure inside" |
