05-27-2013, 12:54 | #1 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1837758 Status: Offline Sonork: Astral7 Thanks Meter: 1 | Samsung Ace Charging socket jumper, need help please in the charging socket (which has 7 pins) most of the pads torn off, except pin 1, 3, 6, 7. I believe that 6 and 7 is ground. my problem is I don't know where to connect pin no. 2 that closes the circuit. I don't need the data pins, I only need it to be charged. any chance that someone knows to were should I connect it??? tried to look inside the repair manual, but didn't understand nothing. I tried all kinds of variations and wasted on it almost a whole day to work it out. every help will be appriciated! IMG_0824.jpg |
05-28-2013, 08:19 | #2 (permalink) |
Member: 1837758 Status: Offline Sonork: Astral7 Thanks Meter: 1 | tried this solution: no charg.JPG and when I connect it to charger - the led of the charger turns off looks like it shorten the charger... anyone?? |
05-29-2013, 12:14 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung gt-S5830 charging pin 1 = Vbus to C617 pin 2 = usb DM to R605 pin 3 = usb DP to R606 pin 4 = usb ID to 20 pin (U601 ic usb) pin 5 = ground pin 6 = vbat to C624 pin 7 = ground only thank button | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
