Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-24-2010, 12:10   #1 (permalink)
Member: 681216
Sonork: 100.1584492
Thanks Meter: 177
Samsung C3303 Connect to PC
Samsung C3303 Always show Connect pc
How can i solve it
The Following 2 Users Say Thank You to rezactgbd For This Useful Post:
Old 03-09-2011, 09:08   #2 (permalink)
Member: 746619
Thanks Meter: 4
Same problem here, can any one help us?
Old 03-09-2011, 12:22   #3 (permalink)
Member: 134237
Thanks Meter: 4
How can i solve it
clean charging jack with alcohol and resolder on-board pins all. it always works. gud luck
The Following User Says Thank You to optimus For This Useful Post:
Old 03-11-2011, 14:03   #4 (permalink)
adampurhawks's Avatar
Member: 258154
Thanks Meter: 317
Thanks a lot bro...it really worked for me
wbr
Adampur Hawks
Old 03-12-2011, 05:40   #5 (permalink)
Member: 383823
Thanks Meter: 28
For me change charging port and worked fine
Old 04-28-2011, 09:09   #6 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
It also works for me.
Old 06-15-2011, 17:23   #7 (permalink)
kau
kau's Avatar
Member: 79914
Thanks Meter: 15
hi
i was change charging base but same also remove capacitor near charging base problem is same please help me
Old 06-19-2011, 10:10   #8 (permalink)
Member: 577307
Thanks Meter: 57
yes you are correct bro it is working. thanks for solution keep it up.
Old 11-27-2011, 06:38   #9 (permalink)
Registered User
Member: 818659
Thanks Meter: 13
samsung c3303 champ allways shows connecting to pc, continues charging hoe can solve it
Old 11-27-2011, 07:51   #10 (permalink)
Member: 1493461
Thanks Meter: 7
Try to remove the vibra motor, I had one with such a fault...
Old 11-27-2011, 07:55   #11 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,852
chack
change battery
Old 11-27-2011, 15:59   #12 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 353
Its the very common fault in this model, 1st remove two capacitors near charging socket then rehot charging ic..........
Old 07-26-2012, 04:15   #13 (permalink)
cellton512's Avatar
Member: 1049912
Sonork: cellmast
Thanks Meter: 102
c3303 connecting to pc , samsung C3303 auto charging
On samsung c3303k some time due to electricity problem it show auto charging.For repair that kind of problem just remove marked capisitor auto charging problem will be solved.In some board,s there are 2 capisitor on marked area, just remove them and check it will stop auto charging 100%. tested by me many time.
The Following 4 Users Say Thank You to cellton512 For This Useful Post:
Old 10-20-2012, 14:13   #14 (permalink)
Member: 986919
Thumbs up auto charge
change plugin brothers...!!! 100%
Old 06-19-2013, 15:27   #15 (permalink)
Member: 476832
Thanks Meter: 21
remove two capacitors near charging socket and change charging base
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.41314 seconds with 8 queries
