Hey, so, I have this older T469, definitely not one of Samsung's best phones... Not by a long shot. Never the less, I decided to experiment with the thing, unlock it, mess with some internals, perhaps even make a custom OS/Firmware for the P.O.S.. Fortunately I use my unlocked BB Curve as my primary cell, not this piece. Here's my problem, though. I was going through the admin menus, running Runtime tests, flash tests, ram tests, etc, etc. Once I finished, I decided... 'Maybe a full on, wipe every single scrap of info from the phone, DM Reset would get rid of some obstacles' (The phone freeze when you put in a SIM card, for instance.) However, things did NOT turn out how I had planned and the thing doesn't even turn on to the home screen, anymore. It'll pop on, get about 3/4 of the way through the initial 'Galaxy 2 splashed' load screen. Then a blue, from what I can tell, debugging screen pops up. I can't exit the screen, with the exception of the option it gives, holding 0 for 2 seconds to reset the device, to which the Boot Loader screen shows upon reactivation of the handset. No matter how many times I pull the battery, reset it, or whatever. I've tried every possible button combination I can think of to bypass the screen, but I believe that I may require an entire flash and reinstall of the firmware. :/
Here are a couple screens, they look horrible, but cell phones don't take good pictures of cell phones, and it's not like I have a screenshot app I can use on that POS. You can't read what it says, but it's suppose to just be a general visualization. It's displaying something about
: After my SW, HW, IMEI, etc at the top, 'ASSERTION_ASSERT:bFound = = TRUE failed. <File .. \SHP3\System\MemMgr\MemMgr .c, line 1077> _ _ MemGetBlockInfo: There is NO allocated memory block with this address. <pb = 0x43694CC, iHeap = 0>, Called from <".. \SHP3\System\RegMgr\RegMgr .c" :650>' Etc, etc, etc. Mostly just a bunch of event logs and code lines, after that. :/ Any ideas? Thanks in Advance, anyone who can give me a hand!
