Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-03-2013, 08:20   #1 (permalink)
Member: 1698929
Thanks Meter: 3
Arrow Samsung c3322 showing charging indication but battery empti pls help.
Friends, My Samsung Gt-c3322 having charging problem.. In battery connecter charging voltage variation 4.7 & 3.9 is there, showing charging indication but battery not stored.. change the btry cnctr & btry.. But problem is same. Please any body help me urgent... Thanx..
Old 07-03-2013, 11:24   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
samsung gt-C3222 charging
first: U309 rehot ... if it still work as before check the voltage
U309 in the C302 and C306 .... if it still works well ... replace U 309
also check its charging ways .... see picture below
only thank button
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 07-03-2013, 12:10   #3 (permalink)
Member: 1698929
Thanks Meter: 3
Thanks for quick response.. But I want Gt-c3322 charging solution... Help me..
Old 07-03-2013, 15:01   #4 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,629
samsung gt-C3322 charging
try to check the working voltage at C302 and C309 U301
If both is still good ... rehot or replace U301
if you still like the original check charging path of the charging socket
see the picture below
Old 07-06-2013, 08:45   #5 (permalink)
Member: 1698929
Thanks Meter: 3
Sir,Thanks for the reply.. In my charging connector ways are like this(attached image) please give me a charging ic's v+ input & output ways.. some time comming charger plugged out/auto charge..Please help me.
File Type: jpg samsunggt-C3322chargingways_zps12e9822b.jpg (40.5 KB, 1126 views)
Old 01-13-2014, 16:38   #6 (permalink)
Temporary banned !!
Member: 1206826
Thanks Meter: 2
samsung c3322 i charging way
Old 08-22-2015, 15:14   #7 (permalink)
Member: 2419050
Sonork: 9900436526
my 3322 usb d+ d_ boot line ways plisssssssssssssssssssssssssssssssssssssssssssssss ssssssshelp me
The Following User Says Thank You to naseerhusain For This Useful Post:
Page generated in 0.14517 seconds with 10 queries
