Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 05-26-2011, 14:41   #1 (permalink)
Crazy Poster
Member: 938635
Thanks Meter: 18
Samsung Champ C3300k Mic solution
[IMG]http://2.bp.********.com/-t_8_3fI5APY/TZow3ya6BEI/AAAAAAAAAXw/feNkh3YjMo0/s1600/Samsung+champ+Mic+Solution.png[/IMG]This is another solution we spotted for Samsung Champ C3300k Not working microphone problem. This solution below is a modifying method on replacing the 5 pin digital microphone with the standard two pin microphone. This may help if you having hard time finding a new replacement microphone, but if you have a replacement spare just replace the microphone and disregard this solution.
The method is by using a 5K resistor to other mic terminal then soldered both the positive and ground pins of the standard microphone... We've not already tried it, so just try it by yourself.
The Following 4 Users Say Thank You to ringlord For This Useful Post:
Old 06-30-2011, 11:23   #2 (permalink)
Member: 201209
Thanks Meter: 5
anyone tried this? is it working?
Old 06-30-2011, 11:30   #3 (permalink)
Member: 943187
Thanks Meter: 383
its working for me. and tested...
Old 07-08-2011, 12:32   #4 (permalink)
Member: 202849
Thanks Meter: 2
can u help me to find 5k resistor
The Following User Says Thank You to shank_sg For This Useful Post:
Old 08-05-2011, 09:06   #5 (permalink)
Member: 140959
Thanks Meter: 9
hi
putt the 4.7 from nokia not charging solution
Old 08-05-2011, 09:37   #6 (permalink)
Member: 140959
Thanks Meter: 9
I just finished my first one and it works pretty well. thank you mr ringlord. and as I said 4.7 resistor from nokia boards that one for the not charging solution. thx all
Old 08-16-2011, 20:03   #7 (permalink)
Member: 1636566
Sonork: sharif1985
thanks ,,,,i have tested its working,,,,
Old 08-25-2011, 10:12   #8 (permalink)
Member: 1077014
Thanks Meter: 2
thanks..........its working fine......
Old 08-29-2011, 11:41   #9 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
thanks guy nice solution . . .
Old 09-08-2011, 09:17   #10 (permalink)
Member: 923315
Sonork: adyserv
thank you!tested and it work!
Old 10-05-2011, 05:54   #11 (permalink)
Member: 112190
Thanks Meter: 15
works perfect 4,7k
thanks
regards
linterna1
Old 10-16-2011, 12:28   #12 (permalink)
Member: 1176498
can show me the resistor?thank you so much
Old 10-29-2011, 21:15   #13 (permalink)
Member: 803646
Thanks Meter: 17
yes it's working for me , But resistance using 4.7k Found in the sony ericsson
This image of the resistance
phone w850 or w830
The Following User Says Thank You to mamdo For This Useful Post:
Old 01-21-2012, 17:34   #14 (permalink)
Member: 108951
Thanks Meter: 26
Thnak u a lot solution work with me
The Following 2 Users Say Thank You to omarfilali For This Useful Post:
Old 03-31-2012, 09:21   #15 (permalink)
Member: 120029
Thanks Meter: 12
I had one phone c3300k with mic problem. I bought 5 replacement mic's (digital), 4 of them didn't work at all and one worked but with very low volume. After consuming all the replacement mic I tried the solution from the 1st post , I looked for a 5k resistor and one small mic and after I solder the two parts the mic worked perfect.
In conclusion GOOD SOLUTION!! Thank's!
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 11:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 04:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 10:56
5110 version 5.24 solution lampin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 06:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.40793 seconds with 8 queries
