samsung e1081t earpiece problem....loudspeaker and ringer working properly. masters,,,, pl help me...my samsung e1081t have strange problem.......:confused: it has no incoming voice on normal speaker while loudspeaker and ringtone work properly:rolleyes: i had found solution on net ....to change the charging jack...:) but after changing it problem still the same:mad: what to do????pl guys help ...:( |
pl help me...my samsung e1081t it has no incoming voice on normal speaker while loudspeaker and ringtone work properly. |
change the charging jack...100% ok |
Yes ... Take Our charging jack from the board.. clean the pads on the board ....check phone without jack... If same problem check the small chip components near to charging connector... Sure your problem will solve Prajith mobile hut |
clean charging jack...100% ok |
clean charging jack...100% ok tested by me.... |
yess its done.....thanx |
plz halp me plz halp me |
riger problem e1081t hlp me how to jumper use. |
change 6 pin small transistor near charging jack 1000000% OK i have done many sets |
clin the charging jack stil same problem when change charging jac 1000000000% ok tested |
`change charging connector 10000% tested |
Don't post any comment on any problem as 100% or 10000000% brothers please ! B cause it stops us for tracing the solutions for best. Thanks. |
Nice atitude bro. thanks. |
If you observe That he is a soldier Always resold ! !!!!!!!!!!!!!!!! Effectively only resold the load pin and works 1000000000% :p:p:p:p:p:p sound On the horn again !!!!!!!! .................................................. .................................................. ... |
