05-15-2014, 07:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2012 Location: INDIA
Member: 1740430 Status: Offline Sonork: 100.1627542 Thanks Meter: 198 | samsung e1282t network problem samsung e1282t network problem any solution plz help me water damage set only searching thanks in advance |
05-15-2014, 07:30 | #3 (permalink) |
Junior Member Join Date: May 2014
Member: 2185335 Status: Offline Thanks Meter: 0 | What is a Temperature Controller and how does it work? A temperature controller is an instrument used to temperature controller . It does this by comparing the process temperature (process variable) with the desired value (set value). The difference between these values is known as the error (Deviation). Temperature controllers use this error to decide how much heating or cooling is required to bring the process temperature back to the desired value. Once this calculation is complete the Mini Double Probes Digital Thermometer will produce a signal that effects the change required. This output signal is known as the manipulated value and is normally Temperature data logger to a heater, control valve, fan or some othe "final control element" which actually injects or removes heat from the process. |
04-30-2015, 10:32 | #5 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | e1282t mostly repair network by softwer many set done... http://forum.gsmhosting.com/vbb/f684...epair-1930808/ |
