11-12-2012, 22:35 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | First, what is sets history, was it drop hard to surface? if yes This is problem from either cpu or flash ic, i get many sets this problem, try rehoting from pcb under, note heat must be gentle(reduce pressure) cause componenets are glued, if u are lucky,that is if bga balls still intact you will get working set again. ... |
The Following User Says Thank You to thomp4pal For This Useful Post: |
