Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-07-2012, 10:59   #1 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,655
Arrow samsung e2232 charging solution 100% tested
Press Thanx Button
The Following 5 Users Say Thank You to jawedakht For This Useful Post:
Old 05-02-2013, 07:11   #2 (permalink)
Member: 1711703
Sonork: 124
if i do this set gone so hot?????????????????
The Following User Says Thank You to manwer2010 For This Useful Post:
Old 05-19-2013, 09:12   #3 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,655
Arrow
no hot bro.................................
Old 07-24-2013, 21:17   #4 (permalink)
Member: 113442
Thanks Meter: 9
yes . pcd gone very hot. dont use this jumper.
The Following User Says Thank You to jitmobile For This Useful Post:
Old 08-30-2013, 00:19   #5 (permalink)
Member: 1584807
Sonork: 100.1620305
Thanks Meter: 3
thish jumber don't use ,power ic damage .
Old 11-15-2013, 07:25   #6 (permalink)
satyakv's Avatar
Member: 1265967
Thanks Meter: 220
http://img51.imageshack.us/img51/8238/e0h3.jpg
short this jumper
The Following User Says Thank You to satyakv For This Useful Post:
Old 12-07-2013, 15:20   #7 (permalink)
Member: 2067739
Sonork: 100.1627266
Thanks Meter: 49
my set is dead thiese jumper
Old 12-10-2013, 10:55   #8 (permalink)
Member: 2058485
Sonork: zainuasai
bad solution ...... set heet
Old 12-26-2013, 08:35   #9 (permalink)
Member: 1569262
Sonork: 100.1615213
Thanks Meter: 8
your soluton is perfect its woring
Old 01-26-2014, 14:25   #10 (permalink)
Mithunvkl's Avatar
Member: 1779640
Thanks Meter: 16
Bad solution my set is dead now
Old 06-01-2014, 18:04   #11 (permalink)
Member: 1553201
Thanks Meter: 3
Angry no experence of any voltages ,who give this solution.dont mis guide
it is very dangerous to jumper,because one is v charge in voltage and other is power distribution voltage which supply other section ,so if 5 volt give to other supply then set also get dead its normal and also remember that 5-volt not used any section accept charge-in.the jumper seen in picture ,its no logic of chargeing solution
Old 09-06-2014, 13:21   #12 (permalink)
Member: 1387849
Sonork: 100.1623264
Thanks Meter: 9
samsung e2232
Originally Posted by jawedakht View Post
Press Thanx Button
this solution not working any other solution ????
The Following 2 Users Say Thank You to i_4_u89 For This Useful Post:
Old 11-08-2014, 06:39   #13 (permalink)
Member: 1710992
Sonork: nibu
Thanks Meter: 24
Red face E2232 auto charging
E 22320AUTO CHARGING PLS HELP
CHARGING JACK CHANGE BUT SAME
Old 12-11-2014, 10:27   #14 (permalink)
Member: 1569262
Sonork: 100.1615213
Thanks Meter: 8
middle of the resistor is correct
Page generated in 0.59144 seconds with 7 queries
