08-18-2008, 18:52 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | Samsung E250 Sound Problem I have two samsung e250. that on sound is ok but no speaker and earpiece sound and always show memory card simple in display without memory card any solution to this problem thx Sharaz |
01-26-2009, 17:41 | #4 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: pakistan Age: 43
Member: 705991 Status: Offline Thanks Meter: 115 | Quote:
i have flashed the phone with both e250d files but still the same problem when i was flashed my phone with e250 files so both sound and memory card was working ok but incoming and outgoing problem i have write all type of eeprom but still the same. when i was flashed my mobile e250d files so incoming and outgoing ok but memory card show, i want to know what is the problem in it, i have tried all the flash files with e250d and e250 but still the same. have any other solution? | |
01-26-2009, 20:45 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | flash it with E250D_27_JBGJ1.sfl and E250D_27_JBGJ1.sff first check on erase full flash cheap eep/mcu and then flah with this file ur problem will be solved but u will get imei 000000000000000 no problem everythin will work fine and if u want to rebuild imei then u must write a good imei .. u may get here http://forum.gsmhosting.com/vbb/show...8&postcount=15 and then u should rebuild with original imei tested many times |
01-27-2009, 08:57 | #6 (permalink) | |
i have solved many phones with this above method but this unit can't solved yet | |
11-08-2009, 15:20 | #8 (permalink) | |
Freak Poster Join Date: Aug 2005 Location: Bangladesh. Age: 41
Member: 174830 Status: Offline Thanks Meter: 34 | Quote:
samsung E250 camera problem | seyit | Samsung Hardware Repair | 8 | 05-29-2015 04:37 |
Samsung E250 unlock problem with original HWK , solution ? | shimano1234 | HWK | 6 | 12-30-2010 09:36 |
samsung e250 ringer problem | saqi160 | Samsung Hardware Repair | 13 | 02-21-2010 11:25 |
samsung e250 power problem | saqi160 | Samsung Hardware Repair | 1 | 12-05-2008 18:42 |
samsung e250 sound problem | Nasir hayat | Samsung Hardware Repair | 2 | 10-05-2008 21:35 |
