09-16-2008, 05:28 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 863045 Status: Offline Thanks Meter: 0 | Samsung G800 Problem.. Sometimes the screen will be fine, but then half the screen will go fuzzy or the screen will split in half. Also, the phone works fine apart from this problem. Thanks. |
09-16-2008, 07:04 | #2 (permalink) |
Junior Member Join Date: Sep 2008 Location: Perth WA
Member: 862359 Status: Offline Sonork: shadowpaw Thanks Meter: 2 | Suggestion The g808 you have needs to be checked out to find the exact cause however if you have the tools you can try yourself. Replace the LCD - if new one works then you know for sure Change ribbon and try Change front board if still not working then it'd be your display intergrated circuit quite hard to give exact diagnosis without the phone in hand Shadowpaw |
Samsung G800 flash problem | Street28 | Samsung Flashers, Software, Firmware. | 36 | 04-08-2011 20:52 |
samsung g800 flash problem not concat with box | Master Software | Z3X-Team Products | 3 | 03-05-2010 20:57 |
problem in samsung g800 | askaralikp | Z3X-Team Products | 1 | 02-25-2010 15:02 |
samsung G800 and E250 Problem !! | seoood | Samsung Hardware Repair | 3 | 06-29-2009 19:25 |
samsung g800 updating firmware problems | flip13 | Samsung Flashers, Software, Firmware. | 2 | 03-26-2008 20:14 |
