Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-09-2012, 19:58   #1 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
Samsung Galaxy Note N7000 Charging issue
hi to all!
i have one galaxy note n7000 in charging problem!
when i connect charger to switched off phone then phone willget on and start charging but when remove charger and connect again to switch on phone it will not charge not connect with usb,
i have changed complete charging jack with flex cable but still same!
can any one give me schematic or charging ic location?
thnx in advance.
br
Old 10-10-2012, 02:36   #2 (permalink)
Member: 1779635
Sonork: a9dc5346107d9bac95b76417
Thanks Meter: 17
try change this one boss....
https://encrypted-tbn1.gstatic.com/i...h3byjEDRutt63P
Old 10-10-2012, 04:25   #3 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 116
Connector of the charging flex area, but on the other side of the board, there is a dual filter for USB lines, remove and jumper it.
Old 10-10-2012, 05:05   #4 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
Originally Posted by alljin View Post
thanks for reply with picture!
as i have mention in my first post that i have already changed charging jack with flex cable!
so the problem is from motherboard not from flex cable!
br
Old 10-10-2012, 05:06   #5 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
thanks alot for reply, can you please post a picture and mention that filter ?
br
Old 10-10-2012, 11:31   #6 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 116
br
I dont have any N7000 here now, but check this picture, as far as I remember that one is the filter, easy to check, D+ and D- from USB connector should go on that filter thru the flex connector from the other side.
Old 10-10-2012, 15:51   #7 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
thanks alot for reply.
i have checked that filter those are ok, show continuity!
can i have schematic for n7000 or charging ic location please?
br
Old 10-10-2012, 17:08   #8 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
i have traced charging ic, seems charging ic is damage, because i have reball charging ic but still same problem,
anyway thanks alot for your concern.
br
Old 04-29-2013, 11:37   #9 (permalink)
Member: 1780582
sir i have same this problem n7000 charging and also change flex and jack but my problem is still same so pls help me for charging ic bc i dont know where is charging ic thats why pls give me location thankls in advance
Old 04-29-2013, 16:45   #10 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,511
Check image i have marked Charging ic in red circle.
br
.::M Irfan::.
The Following 2 Users Say Thank You to .::M Irfan::. For This Useful Post:
Old 07-29-2014, 15:55   #11 (permalink)
Member: 1708464
Sonork: manavrohilla
Sir first dry ur charging ic..mostly it works then u can change it..ur problem will solve....i hv do this many time n sucessed
Old 06-03-2015, 19:30   #12 (permalink)
Member: 2133719
sir just reheat....................................
Old 06-16-2015, 11:15   #13 (permalink)
Member: 2349619
Thanks Meter: 5
Any new tricks to fix note 7000 flexyble usb without replace it?come masters here give solution.
Old 08-29-2015, 13:35   #14 (permalink)
Member: 1423806
Thanks Meter: 17
Please look at my board
The IC is missing! Probably it was b l o w e d off.
I own hot air gun station but I never used in such of small components. How can I solder back a new IC WITHOUT flowing the other parts around? (cause that was my issue before when trying to solder small components: they was flowed away easyly).
Maybe there is a video tutorial with soldering very small components?
Old 05-16-2016, 23:40   #15 (permalink)
Member: 2558127
Thanks Meter: 2
hi all
is it possible we jumper that ic?
Page generated in 0.33287 seconds with 8 queries
