10-01-2014, 20:27 | #168 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1126640 Status: Offline Sonork: abv Thanks Meter: 0 | Hello Masters, I've bricked my device by repartion with pit file but somehow ODIN freeze during flashing I was forced to pull out USB cable then my S2 doesn't work anymore just deep dead no enter into Download mode, no recovery just nothing. So I sent my device to service for JTAG but they don't repair my phone, from service told my device don't want receive(accept) repair file from JTAG box Octopus(and some other Box). After this I checked on my motherboard has been removed U503 and C565. If I was again sent to another service center can still my device work without this components on motherboard. Actually anyone who have experience on JTAG repair why my device don't receive repair file from JTAG Box, Is there any problem with EMMC chip ? Thanks |
10-17-2014, 13:04 | #169 (permalink) | |
Freak Poster Join Date: Feb 2012 Location: Lebanon
Member: 1726910 Status: Offline Sonork: 100.1623945 Thanks Meter: 41 | Quote:
10-18-2014, 12:45 | #170 (permalink) |
Crazy Poster Join Date: Oct 2014
Member: 2276310 Status: Offline Thanks Meter: 2 | Hi dears, i have a problem with board, i have removed the capacitor and the phone not power on, i can remove the ic power? the board starting without ic power component. Thank you very much in advance! Al. |
11-01-2014, 22:05 | #173 (permalink) | |
Member: 1126640 Status: Offline Sonork: abv Thanks Meter: 0 | Quote:
Only service repair center can make this thing. Probably I need from new motherboard. With which box can be performed emmc direct flash ? Can replacing of emmc chip may help me, bootloader where it is stored ? | |
11-06-2014, 16:50 | #174 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2149199 Status: Offline Thanks Meter: 0 | different solution hi guys, i tried to remove capacitor, also IC and also IC that is below, nothing of that helped. Then I removed everthing near, also did not help. Phone was still be able to start and be functional normally, but overheat and fast battery drain. Solution for me was: There is big IC on the OTHER SIDE of logic board that is near the small battery i removed it (phone did not start)....so I replace it with another one, which i took from my another motherboard (was dead, but because of another problem). Worked perfect for me, phone is charging normally and not heating. Wish you a good luck, guys. |
04-06-2015, 08:18 | #175 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2338170 Status: Offline Thanks Meter: 1 | bro my s2 is getting automatically on after inserting battery,but the lock key function is properly working and power off restart and flight functions are properly appearing when we hold power key .. the only problem is the set is getting on automatically.. plzz any helppp |
04-07-2015, 10:12 | #176 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
04-09-2015, 10:33 | #178 (permalink) |
No Life Poster Join Date: Oct 2009 Location: attock Age: 35
Member: 1147735 Status: Offline Thanks Meter: 156 | hi dear all master i have face a problem i9515 the problem is when i power on phone if power supply vol=4.5 just 0.4 imp and not power on still 0.4 imp after release power button i check Near U800 c835 and c838 no short equal value i also check OSC800 i have lot of search forum and many JTAg option but my phone not power on may be i think my problem ON NEAR BATTERY TERMINAL PLZ CHECK MY REAL PHONE PIC ON HERE PIC 1.... AND PIC 2... VERY THANKS FOR ALL MASTERS BEST REGARD: WAQAS NADEEM |
04-09-2015, 14:13 | #179 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @waqas317, You here are in totally Wrong Thread....and you have just posted the same problem in other thread..cannot do it becouse when customer use Search button you misguide posting in many thread the same thingh. This thread is ONLY for I9100 in Short Circuit. BR |
05-14-2015, 16:22 | #180 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | i remove the capacitore i remove u501 ic i remove u503 ic the phone is still shorted help please |
The Following User Says Thank You to habibboxes For This Useful Post: |
