12-01-2012, 22:26 | #17 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1847125 Status: Offline Thanks Meter: 1 | the capacitor has no inscription, as I can recognize it when i see it in other phone?. P.D: I could solve the problem shorting circuit the capacitor, but i want to replace it, but i donīt know where can i found and recognize it Last edited by mativillar; 12-01-2012 at 22:31. |
12-05-2012, 15:00 | #20 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1793866 Status: Offline Thanks Meter: 1 | Hello, I also removed the IC (U503) and the phone was working again. for your information: the IC is responsible for supplying (5V) external devices. If you dont use this function, the phone will work fine without it. |
The Following User Says Thank You to postman976 For This Useful Post: |
12-18-2012, 19:24 | #21 (permalink) |
Member: 1854904 Status: Offline Thanks Meter: 3 | hello, i'm a new user over here and like too much this forum my international galaxy s2 had a trip in the washing machine 4 days ago first boot everything is working but my only issue is that the battery show 0% and can't be charged i ordered a new one but i still have the same issue, when plugged to a charger i have a battery icon inside a yellow triangle and when unplugged the phone starts by it self i did several search on the internet and i found out that it can be also from USB FLEX CABLE i need some advices please thx a lot |
The Following User Says Thank You to zool84 For This Useful Post: |
12-19-2012, 01:22 | #22 (permalink) |
No Life Poster Join Date: Jun 2007 Location: France 72,77
Member: 521955 Status: Offline Thanks Meter: 261 | try without charge connector if phone start by itself. If no the problem is usb connector. |
The Following 2 Users Say Thank You to orangade For This Useful Post: |
12-23-2012, 18:48 | #24 (permalink) |
Major Poster Join Date: Nov 2012
Member: 1843401 Status: Offline Thanks Meter: 12 | I have a problem of short circuit very similar to the one you solved. In practice unsoldering SMD and IC I always have a short circuit to the battery connector .... also in 2 SMD down near the tongue touches the contact of the hands on the same side of the IC and SMD me by a short circuit ... there 'this method over other component that needs to be replaced? Could you help me in this my difficulty ... cards affected by this issue are three in my possession. Best Regards |
The Following User Says Thank You to knap For This Useful Post: |
12-23-2012, 19:14 | #25 (permalink) | |
Member: 1843401 Status: Offline Thanks Meter: 12 | Quote:
12-31-2012, 13:43 | #27 (permalink) |
Member: 1859973 Status: Offline Sonork: 100.1625588 Thanks Meter: 2 | ..it's all well & good telling people about this fix but it isn't a fix until you replace the dead part. also bear in mind that the ic next to the capacitor may be fried but you dont get to find that out until you Replace the capacitor !!! |
The Following User Says Thank You to unlockapple For This Useful Post: |
02-01-2013, 20:19 | #30 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1877476 Status: Offline Thanks Meter: 1 | Hi, My Samsung Galaxy S II Skyrocket i717 for AT&T USA is having the same problems. Which capacitor do I remove to make it work again? Here is my picture of the motherboard: Thanks! |
The Following User Says Thank You to xmen08 For This Useful Post: |
