Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-17-2012, 17:28   #1 (permalink)
Member: 412812
Thanks Meter: 97
Arrow Samsung Galaxy S2 I9100 short circuit solution.
Samsung Galaxy S2 I9100 water damage and sometimes low quality charger create full short circuit here is the solution to all of my friend.
The Following 12 Users Say Thank You to krish neupane For This Useful Post:
Old 09-18-2012, 16:49   #2 (permalink)
Member: 412812
Thanks Meter: 97
If not done first solution then try this final solution.
The Following 2 Users Say Thank You to krish neupane For This Useful Post:
Old 09-25-2012, 08:20   #3 (permalink)
Member: 1815680
Sonork: 100.73934
If not done first solution then try this final solution. Samsung AA-PB4NC6B
The Following User Says Thank You to rustking For This Useful Post:
Old 10-06-2012, 15:56   #4 (permalink)
Member: 412812
Thanks Meter: 97
Thanks dear for your reply....yes mostly damage this capacitor and repair 10-12 phones by myself.
Old 10-21-2012, 11:40   #5 (permalink)
Member: 309277
from any mobile can i find that capacitor pls? when i removed it the mobile turn on good but no charge >help me plsssss
Old 10-22-2012, 14:06   #6 (permalink)
Member: 267976
..it's all well & good telling people about this fix but it isn't a fix until you replace the dead part. also bear in mind that the ic next to the capacitor may be fried but you dont get to find that out until you Replace the capacitor !!!
Old 10-22-2012, 14:25   #7 (permalink)
Member: 267976
the ic next to the capacitor is a max8627 -readily available & cheap if yours is dead.. a lil tricky to fit, but hey... the datasheet is here - MAX8627 datasheet pdf datenblatt - Maxim Integrated Products - Low VBATT, 20uA IQ, 1MHz Synchronous Boost Converter with True Shutdown ::: ALLDATASHEET ::: from that pdf & diagram you get a rough idea of the capacitor value.. connected between pins1(gnd) & 4&5(batt).. schematic for ic states that 2 ceramic 22uf capacitors are used.. in the absence of any more information i'd be inclined to just try a 22uf cap in place of the dead part...
Old 10-22-2012, 17:17   #8 (permalink)
Member: 267976
part is ceramic capacitor 22000nF
Old 10-26-2012, 23:04   #9 (permalink)
Member: 68842
Thanks Meter: 6
hi
but where to find MAX8627,on some other phone?
Old 10-27-2012, 06:10   #10 (permalink)
mengaik33's Avatar
Member: 151678
Thanks Meter: 20
cant see first post pic,,,pls share it
The Following User Says Thank You to mengaik33 For This Useful Post:
Old 10-31-2012, 16:07   #11 (permalink)
Member: 267976
Originally Posted by fill View Post
hi
MAX8627 Low VBATT, 20ľA IQ, 1MHz Synchronous Boost Converter with True Shutdown - Ordering Info
google is a wonderful thing & maxim offer a free sample of this part or they will sell direct to you if you cant get it in a shop, but any reputable electronic supplier will order pretty much any part you ask for - just to get your business.
Old 11-12-2012, 19:21   #12 (permalink)
Member: 5345
Thanks Meter: 29
where I find capacitor c565 (C-CER,CHIP;22000nF,20%,10V,X5R,TP,1608,0) in other phones nokia, samsung or sony ericsson ? because I have demaged this capacitor.
Old 11-21-2012, 15:19   #13 (permalink)
Member: 412812
Thanks Meter: 97
sorry for late bro you can change this capacitor from any pcb for example nokia 3110c power section there you can find choose any one.
The Following User Says Thank You to krish neupane For This Useful Post:
Old 11-25-2012, 21:20   #14 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 205
Thanks krish neupane !!
I solved two s2 i9100 by this method. This capacitor is shorted. For detect if this, before change capacitor, control gsm battery connector if is shorted between vbat and ground, for me is that; after change C, all is well.
THANKS!
[/QUOTE]
Old 12-01-2012, 12:48   #15 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 205
Another s2 solved by this method. I just remove the capacitor.
Page generated in 0.35404 seconds with 8 queries
