Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-20-2013, 14:33   #31 (permalink)
FON-TECNO's Avatar
Member: 1201378
Sonork: 100.1594717
Thanks Meter: 303
Thanks Mate it work 100% and phone can still charg but what i will like tokn is it they will be no problem later
The Following User Says Thank You to FON-TECNO For This Useful Post:
Old 02-20-2013, 23:07   #32 (permalink)
Member: 601591
Thanks Meter: 86
thanks still where can we get that ic?
Old 02-24-2013, 17:50   #33 (permalink)
Member: 1419056
Thanks Meter: 6
Hello.
I have one Galaxy S2 and it can charge the battery.
But the problem is device always running on MTP mode and Windows cant recognice the device, with charger is on MTP mode, D+ and D- is in shortcut when the usb port is conected with charger or usb-adapter.
Can this fix solve this problem? Maybe this problem is with U502.
Thank you.
Old 03-15-2013, 17:53   #34 (permalink)
starXman's Avatar
Member: 111292
Thanks Meter: 66
Hi friends.
I have here one I9100 with short circuit between + and ground.
allready removed the capacitor, nothing changed, removed the ic, stills the same
and i been removing all those components, mainly diodes where i guess it is shorted,
but still not solved, always shorted, were can it be the problem?
Any help will be much appreciated.
starxman.
Old 03-15-2013, 18:01   #35 (permalink)
starXman's Avatar
Member: 111292
Thanks Meter: 66
by the way if anyone interested in that ic identification,
it is a DC/DC converter and the original samsung spare
number is 1203-006794.
Old 03-16-2013, 14:14   #36 (permalink)
Member: 26358
Thanks for the solution. I had same problem today. I was using 500mA charger instead of original one and thought it was the problem. First i cleaned the board. Nothing. Then heated ic. Nothing again. After a bit research i found this solution and measured Vbat and Gnd. Yea there were short circuit. I desoldered old capacitor and connected new one. (I used 2x 10000 nF parallel cos i cant find 22000 but when i measured parallel caps. it was 22000 nF. For now that was the best thing to do) and i soldered it. It was worked as charm. Seems like everything is ok now.
Old 03-17-2013, 06:55   #37 (permalink)
Member: 1861479
Originally Posted by postman976 View Post
Hello,
I also removed the IC (U503) and the phone was working again.
for your information: the IC is responsible for supplying (5V) external devices.
If you dont use this function, the phone will work fine without it.
Hello,
whats happen wehn i remove the Chip?
I can carge the battery ore conect with the pc?
Old 03-21-2013, 11:08   #38 (permalink)
Member: 1861479
Hello,
i have removet the IC and the capacitor. But the Phone donīt work.
I have removed because when i plug in the Battery the ic become hot.
Now the Phone when i use a power supply instead of the battery the phone take 0,04A.
When i plug in the USB cable to the Phone and a PC the phone take 0,11A.
But the phone donīt start or indicates something.
Someone have a idea?
Old 03-30-2013, 17:50   #39 (permalink)
Member: 1872587
Thanks Meter: 4
Originally Posted by tomatos666 View Post
Hello,
Have 2 the same....
Old 04-04-2013, 22:24   #40 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Hello,
This is a fun info!!! BIG THNX!!!
Old 04-05-2013, 16:25   #41 (permalink)
Member: 1062737
Thanks Meter: 8
i have short on i9100 so i removed the capacitor, now when i test the phone the buzzer beep for second and stop and no POWER..and i have the IC near the led light getting hot
Old 04-08-2013, 16:19   #42 (permalink)
UU2
Member: 21987
Thanks Meter: 27
In the panel on the red marked parts would be replaced by a capacitor 2pcs?
Can someone confirm that the IC without m "works" phone?
Old 04-09-2013, 20:52   #43 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Nobody has encountered this type?
Old 04-19-2013, 10:10   #44 (permalink)
Member: 1916693
Thanks Meter: 2
Hi,
My phone i bought for repair was water damaged. I removed the capacity C565 and I get voltage through the rest of the board (have not replaced the C565). However I can't still turn on the phone.
I'm waiting on a new LCD as the current one is cracked so not sure its because of this that it won't turn on or not.
Do I need to remove the IC or problem is resolved as there is voltage around the rest of the board? I only location where the voltage is not testing ok is next to the EMI filters F703 and F704. When I short them with the multimeter the return and menu buttons power up and phone vibrates.
Any info will be appreciated. Really lost still hopefully LCD part resolves, I will provide an update once I try with new part.
Old 04-23-2013, 13:05   #45 (permalink)
Member: 796626
Thanks Meter: 2
thanks.................. good work keep it up
Page generated in 0.28356 seconds with 10 queries
