Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-25-2013, 19:38   #46 (permalink)
Member: 1916693
Thanks Meter: 2
New LCD works. Now charging problem.
Where can you get D501 and Q500 cheaply from? Which cheap old samsung phone would have this besides S2?
The Following User Says Thank You to Nikkolz For This Useful Post:
Old 04-26-2013, 16:14   #47 (permalink)
Member: 696214
Thanks Meter: 2
Originally Posted by krish neupane View Post
Samsung Galaxy S2 I9100 water damage and sometimes low quality charger create full short circuit here is the solution to all of my friend.
thank to useful post
The Following User Says Thank You to SATHAKATHULLA For This Useful Post:
Old 04-29-2013, 12:01   #48 (permalink)
Member: 323481
Thanks Meter: 24
I have here one I9100 with short circuit between + and ground.
allready removed the capacitor, nothing changed, removed the ic, stills the same
and i been removing all those components, mainly diodes where i guess it is shorted,
but still not solved, always shorted. Any other solution?
Old 04-29-2013, 12:13   #49 (permalink)
Member: 323481
Thanks Meter: 24
The phone is powering on but discharging verry fast...
Old 05-03-2013, 19:02   #50 (permalink)
Member: 695725
Thanks Meter: 4
i have s2 but after i remove the capacitor it still doesnt power on, is there some in uk who can have a look for me,thanks
Old 05-04-2013, 01:56   #51 (permalink)
Member: 20892
Thanks Meter: 6
thanks, i tested this solution yesterday and it did really work!
Old 05-07-2013, 10:37   #52 (permalink)
Member: 1929854
can i just remove the u503 ic without any consequences
The Following User Says Thank You to firebird11 For This Useful Post:
Old 05-12-2013, 18:17   #53 (permalink)
Member: 22105
I just removed that capacitor and phone is working again. Thanks to the original poster.
In my case, I bought a non original battery 2 weeks ago. Maybe it could be another reason for that capacitor fault.
The Following User Says Thank You to KorXo For This Useful Post:
Old 05-23-2013, 11:47   #54 (permalink)
Member: 1944173
This capacitor is fried in my galaxy S2. I will try to desolder it and tell you how it goes.
If not, where can I get this 22uf 10v capacitor? I haven't found it in the most common component sellers.
2203-007781 C564,C565 C-CER,CHIP;22000nF,20%,10V,X5R,TP,1608,0
I think 1608 is the size, which is the thing I'm having most trouble with.
The Following User Says Thank You to paaaam For This Useful Post:
Old 05-24-2013, 20:28   #55 (permalink)
Member: 1944173
I removed the capacitor and disabled the IC like this guy did: [SGS II] Water damage, overheating u503 (USB OTG) and Workaround - Samsung Galaxy S Forums : Galaxy S2 S II Forum
It works now
Old 05-26-2013, 00:41   #56 (permalink)
Member: 1861479
Hello. What happen when i remove the ic and plug in the usb?
Old 05-26-2013, 12:05   #57 (permalink)
Member: 1861479
Hello,
I have a phone with a short circuit.
I have removet the ic. Now when i start the phone i see the samsung logo and than the display are black.
I can go in to the recovery menu but don't help me to start. Some one now a solution?
The Following User Says Thank You to tomatos666 For This Useful Post:
Old 05-29-2013, 23:32   #58 (permalink)
Member: 795617
Thanks Meter: 6
Smile sgh galaxi s2 not working home button
because my friend does not work galaxi s2 home button, the home button flex is fine and I checked, any repair thanks in advance I thank you
The Following User Says Thank You to STEVE84 For This Useful Post:
Old 06-17-2013, 07:03   #59 (permalink)
Member: 1710790
Thanks Meter: 3
iam just remove the capacitor problem slove thanks
The Following User Says Thank You to shaik khaja For This Useful Post:
Old 06-17-2013, 20:12   #60 (permalink)
Member: 1182933
Thanks Meter: 3
Smile usb not working but charging ok....
am also chenge usb strip...same problem... plezzz help eny one 100000 tnx advns........i need usb ic location and usb ways... plz help......plz....
The Following User Says Thank You to shemi4tech For This Useful Post:
Page generated in 0.38566 seconds with 8 queries
