06-18-2013, 09:09 | #2 (permalink) |
Junior Member Join Date: Jun 2013 Location: philippines Age: 51
Member: 1962047 Status: Offline Thanks Meter: 0 | samsung galaxy s3 i9300 dont want to open, when i open it it just the android logo en then the samsung intro only then it will be back to android logo again,,, what am i going to do? please helpppppppppp me please..... |
06-18-2013, 09:24 | #3 (permalink) |
Banned Join Date: Oct 2011
Member: 1681183 Status: Offline Sonork: 100.1637594 Thanks Meter: 65 | try ro this solution this one test on s2 you find ic and replace see this pics Samsung Galaxy S2 I9100 water damage and sometimes low quality charger create full short circuit here is the solution |
06-18-2013, 09:25 | #4 (permalink) | |
Member: 1681183 Status: Offline Sonork: 100.1637594 Thanks Meter: 65 | Quote:
best of luck | |
06-18-2013, 09:35 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | If a phone is short circuit then there is no any specific way to find it . You have to identify it , how ? 1st check which section is direct connect with battery & cut the supply one by one & check . Connect with power supply & check which section is heating . Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
09-13-2013, 19:59 | #6 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | Battery ground-battery + 5ohm....short. It's not warm! If each of you would want to choose components in the positive line...should bomb the whole phone apart! Sacrificing one.....someone did not try it? I tried a i9100 ....I started each harvested capacitors, transistors /which were between the power and ground/ then came the ic....the fault persists even after the Max8997 IC dried. But you're not warmed up! I should also do the same here! |
05-10-2014, 11:49 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: Motalib Plaza,Dhaka,Bangladesh Age: 39
Member: 485407 Status: Offline Sonork: 100.1580486 Thanks Meter: 183 | Quote:
Battery ground-battery + 5ohm....short. I see you everywhere with short problem. Do you have any tested way to solve such problems? share it .. if not want to share here pm me. | |
