Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-16-2015, 02:36   #16 (permalink)
Member: 1678566
Thanks Meter: 16
Yes any help. I can't fix this problem
Old 02-16-2015, 19:10   #17 (permalink)
Member: 2321410
change 325A transmitor ic 99% working....
Old 02-19-2015, 13:32   #18 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
Originally Posted by tariqmobilelab View Post
i change the sound ic butt same problem. not working sound after call
i try to flash with modem file.
Old 02-28-2015, 06:27   #19 (permalink)
Member: 1678566
Thanks Meter: 16
WHere is this exactly on the board?
Old 03-06-2015, 15:09   #20 (permalink)
Member: 2357985
I have solved the problem: dowload app soundabout. Works like a charm for me.
Old 03-23-2015, 11:54   #21 (permalink)
Member: 87810
Thanks Meter: 2
-rehot/replace sound IC,
-Flash modem/ROM
-replacing the 325A
didn't solve the problem ...
anyone with a solution ?
adaseb ... 325A is located next to Sound IC ...
Old 04-13-2015, 22:39   #22 (permalink)
nasro_nd's Avatar
Member: 149415
Sonork: 100.1609895
Thanks Meter: 77
phone dead after change
Old 04-15-2015, 22:46   #23 (permalink)
Member: 2373920
Thanks Meter: 2
Hi guys, I have a problem on my i9505. I'm going mad with it. Everytime the speaker activates I hear a kind of "white noise" or the classical "tititititi" of network handsnake.
The second problem is that I can't use my loudspeaker in handsfree call, no one can hear me (I think a problem with the 3rd mic that I just ordered).
I tried:
1 - new buzzer
2 - new flex cable
3 - Rehot u1004
I can't understand what the problem is. If I use a pair of headset the audio is magically perfect. Someone can help me? Thank you!
Old 04-30-2015, 14:03   #24 (permalink)
Member: 1809436
Thanks Meter: 2
can't locate U605
muhammad arif09
I can not find U605, can you please show me where it is?
I checked multiple diagrams from the web but none show any IC labeled U605..
thanks for your time
Old 04-30-2015, 14:55   #25 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
Originally Posted by kiwi-1990 View Post
muhammad arif09
ic audio gt-i9505 = U1004 instead U605
see picture of his location at the beginning of this thread
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 05-01-2015, 21:27   #26 (permalink)
Member: 2373920
Thanks Meter: 2
Problem solved.
I had a strange noise when the speaker was active. The typical sound that you have when you put your smartphone near an old speaker (network handsnake).
How I solved :
U1000 Rehot (audio amp) near the mic2 and mic3.
Loudspeaker mic solved with a simple change of mic.
Thats all.
Hope that this can help someone! Hi all
The Following User Says Thank You to SeventhSin For This Useful Post:
Old 05-16-2015, 17:51   #27 (permalink)
Member: 2202350
Speaker noice samsung s4 3g pls solution
Old 07-11-2015, 21:40   #28 (permalink)
Member: 2373920
Thanks Meter: 2
Old 08-21-2015, 06:49   #29 (permalink)
Member: 1726210
Thanks Meter: 25
i tested my phon is ok after rebolt
Old 09-26-2015, 13:24   #30 (permalink)
Member: 329458
Thanks Meter: 153
After rehot also my i9505 is fully working.
Thanks a lot!!!
Page generated in 0.20803 seconds with 8 queries
