07-15-2017, 23:35 | #16 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2731548 Status: Offline Thanks Meter: 0 | with no current draw once the phone is turned off and 60mA once the power button pressed is this a sign for bad power ic which is the pm8917? |
07-16-2017, 00:28 | #18 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i recieve 2 s4 mini with no power when press power key it take some amp and needle stuck i replace power ic 3 to 4 times but same may be emmc |
07-22-2017, 20:20 | #21 (permalink) |
Member: 2731548 Status: Offline Thanks Meter: 0 | hello guys i have done some voltage messurements at the pm ic.... photo on link if someone knows or can messure on hes own gt 9195 lte to help me Vin 4v Imgur: The most awesome images on the Internet |
07-23-2017, 00:07 | #22 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | friend i recieve 2 s4 mini in no power problem and i work on pmic and other ic but same but i dont work on cpu and emmc bcoz dont have spare to replace these finally pcb replaced because this the only option |
07-23-2017, 02:53 | #23 (permalink) |
Member: 2731548 Status: Offline Thanks Meter: 0 | yep understant you...just try to learn in the same time... if you have those s4 mini and you have time to check some voltages ill be happy to trade some messurements like this on my photo just for the record i really be happy if someone post some voltage from a working s4 mini on my photo .... btw thank you all guys for your time |
08-17-2017, 12:56 | #26 (permalink) |
Member: 2731548 Status: Offline Thanks Meter: 0 | hello again guys.... after some reserch i found the debrick image technic with sd card... i try some random debrick images and now im on this stage..... BOOT RECOVERY MODE: CHECK BOOT PARTITIONS. COPY FROM T-FLASH BOOT RECOVERY WRITE 138008 SECTORS FLASH WRITE FAILURE ddi: mmc_read failed ODIN MODE PRODUCT NAME: GT-I9195 CURRENT BINARY: SAMSUNG OFFICIAL SYSTEM STATUS: CUSTOM KNOX KERNEL LOCK: 0x0 KNOX WARRANTY VOID: 0x0 CSB-CONFIG.LSD: 0x30 BOOTLOADER RP SWREV: 2 WRITE PROTECTION: ENABLE the only way to fix this phone is the jtag for sure but if someone has a proper debrick image with bootloader v2 please upload just to try |
