11-08-2017, 10:25 | #151 (permalink) | |
Junior Member Join Date: Mar 2014
Member: 2157095 Status: Offline Thanks Meter: 0 | Quote:
11-20-2017, 21:20 | #154 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | s6 edge flash light not work remove flash light and use scrap bord led remov led make 2 jumper flash light working and job don Sent from my SM-N920C using Tapatalk |
12-06-2017, 15:11 | #156 (permalink) |
Crazy Poster Join Date: Apr 2007
Member: 496200 Status: Offline Thanks Meter: 3 | This is solution for fast charging and USB device not recognized https://ibb.co/b2BwqG |
12-10-2017, 12:56 | #158 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2787564 Status: Offline Thanks Meter: 1 | S6 edge no Power Hi guys, i need help for my s6 My s6 edge no Power Now, before get a bit freezing with reebot. I tryed to disassebly and after i try to unplug/plug cnt battery and the smartphone worked for a bit but after 2 min getting freezing with reboot and blocked on Samsung logo but Now no Power on and no Power in service mode. No rooted btw What is the cause and solution? Sorry for my bad english Thank u guys |
The Following User Says Thank You to Soulicious For This Useful Post: |
12-17-2017, 05:46 | #160 (permalink) | |
Junior Member Join Date: Dec 2017 Age: 23
Member: 2789943 Status: Offline Thanks Meter: 0 | Quote:
Sent from my SM-J3110 using Tapatalk | |
12-21-2017, 15:41 | #162 (permalink) |
Crazy Poster Join Date: Aug 2006 Age: 44
Member: 323234 Status: Offline Thanks Meter: 4 | G925i touch keys are not working. USB charging and connection works fine, mic is working, HOME is working fine. I dont have another G925i module, I`ve checked on G925f (few pieces) and it is the same. I think that is something on mainboard. Any schematics or solution for touch keys? |
12-29-2017, 19:39 | #163 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1813054 Status: Offline Thanks Meter: 4 | G925F very hot and died no power and not charging have replaced power ic but on usb meter it shows that phone is getting 0.08amp battery tested all good, where else should i look for problems? Thank You |
01-04-2018, 15:12 | #165 (permalink) | |
No Life Poster Join Date: Jun 2014 Location: Bolivia
Member: 2202707 Status: Offline Sonork: whatsapp +59170073722 Thanks Meter: 212 | help Quote:
help please friends | |
The Following User Says Thank You to tomelich For This Useful Post: |
