Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-07-2018, 19:17   #106 (permalink)
Member: 2558762
Sonork: 2011iq
Thanks Meter: 2
G920 f camera ???????
Old 04-18-2018, 02:49   #107 (permalink)
Member: 2829910
Hi pls any ideas for Samsung s6 "hot by temperature"
The Following User Says Thank You to Gadgetandrepair For This Useful Post:
Old 04-18-2018, 04:52   #108 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
" hot by temperature" is affected by thermistor ntc (CHG_THM) and battery thermistor (BAT_THM)
Old 05-07-2018, 17:20   #109 (permalink)
pachicoo's Avatar
Member: 591052
Sonork: 100.1592747
Thanks Meter: 95
have s6 G920f which is completely dead no shortage. when i run through dc supplier the am niddle stop on 0.4A permanent where should be the problem if some one had faced this.
Old 05-28-2018, 21:48   #110 (permalink)
Member: 1733753
Sonork: 100.1627554
Thanks Meter: 4
Hi friends Ibjave s6 g920 tried to change bettry after that turn on but not show image! Some one can add phot where is display IC located thanks
Old 05-29-2018, 03:10   #111 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,629
this samsung G920F's display lcd is sustained by: its lcd working voltage, lcd filter emif and lcd regulator U9001 ... its position open its schematics
Old 10-03-2018, 08:54   #112 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 54
Hi ! Need help with back button sensor . i try wit another flex but not work . model g920f .
Old 12-24-2018, 14:30   #113 (permalink)
Member: 245346
Thanks Meter: 19
Originally Posted by okrongly View Post
Charger pulls 0.44A , tried all solutions and still no luck. Many of them recently
this diode solved fast charge for me
The Following User Says Thank You to IgorIgs For This Useful Post:
Old 01-13-2019, 04:34   #114 (permalink)
Member: 2750143
Attachment 370127
I don't understand this diagram
Sent from my SM-J250F using Tapatalk
The Following User Says Thank You to Royalhunter1 For This Useful Post:
Old 02-01-2019, 15:40   #115 (permalink)
Member: 2570643
Thanks Meter: 4
Hi
A Samsung s6 g920f
No IMEI(null) and baseband is unknown
In combination rom IMEI null , baseband unknown
Problem??? Emmc??? Or?????
Old 05-07-2019, 11:47   #116 (permalink)
Member: 1898289
Thanks Meter: 39
I received a ton as well with maybe same case, in my case, with my charger and USB detector always shows 0.49A. All are S6 / S6 Edge and Plus "casualty"...
VBAT shorted and don't get any componet over hot for the clue
Page generated in 0.25520 seconds with 10 queries
