10-24-2016, 23:26 | #46 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2547055 Status: Offline Thanks Meter: 0 | Also the USB Problem... I also have the problem, that my S6 (920f) deosnīt fast-charge...it charges VERY slow! Also I cannot connect it with my computer...says "unknown device". Apart from that, the phone works well! I have changed the whole USB-Flex...testet another computer, another cable and chargin-plug. I replaced the U8010-IC from the solution above...no luck! Same problem! I really want to solve this problem. Does anyohne have any Idea what to try next? kind regards, flo |
11-08-2016, 17:32 | #48 (permalink) |
Freak Poster Join Date: Jul 2008 Location: bahawalpur pakistan
Member: 821900 Status: Offline Thanks Meter: 26 | glaxy s 6 sim problem i have a set with sim problem all prints are ok its demand restart when insert sim after restart show no sim any solution ???? |
12-01-2016, 14:00 | #49 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2304699 Status: Offline Thanks Meter: 0 | hi all looking for s6 g920f schematic diagram please having problem with the display sometimes its showing then the other second it stops. anyone willing to help as I am new here. regards khalid |
12-29-2016, 12:55 | #51 (permalink) |
No Life Poster Join Date: Apr 2002 Age: 48
Member: 10580 Status: Offline Thanks Meter: 43 | also same problem for me G920F not have any water dame and not dropped l tryed change battery nothing change flex nothing ic rehot nothing not working fast charge and not fing pc unknow device all time |
12-31-2016, 01:54 | #52 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1738922 Status: Offline Thanks Meter: 4 | Mine was a board problem. Tried rehot on ic, no go. Probably cap or resistor on board in ic fast charge circuit. Tested with separate board and battery/flex were fine. There's a schematic floating around here with the full fast charge circuit diagram and testing. |
01-05-2017, 19:35 | #54 (permalink) |
Major Poster Join Date: Jan 2017 Location: peshawar, thall, pakistan
Member: 2669033 Status: Offline Sonork: 100.1676548 Thanks Meter: 10 | first you check the lcd and other you check the lcd jack in main board if both were ok then change the display ic side of other near with bettery terminals |
01-06-2017, 15:04 | #55 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1135025 Status: Offline Thanks Meter: 11 | i'm working in a samsung service center and specialized for G920,G925 and G928, if they charge only at 5V/420mA and sub pba(usb port with flex cable) is ok then in most cases the z-diodes or resistors(ZD8005 / ZD8006,R8021 / R8022) are the problem... if the charging screen pops up on display it has nothing to do with lcd |
The Following 3 Users Say Thank You to cy8ex For This Useful Post: |
02-07-2017, 11:42 | #60 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2420684 Status: Offline Thanks Meter: 2 | Samsung S6 G920A, G920V, G920T, No sim problem Hello Guys! Is there any solution for the problem of no sim on samsung galaxy s6? The phone has imei and everything, when you put the sim on the device it recognize it and needs to restart but after that the still shows no sim card error. Please help if anyone has a solution for this problem. Thanks |
The Following User Says Thank You to samura86 For This Useful Post: |
