02-13-2017, 19:35 | #61 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2669942 Status: Offline Thanks Meter: 0 | |
03-01-2017, 03:15 | #64 (permalink) |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | samsung S6 sm-G920f schematics (without pcb layout) PRESS THANK BUTTON |
The Following 12 Users Say Thank You to d-Artigo For This Useful Post: |
04-07-2017, 15:52 | #68 (permalink) |
Crazy Poster Join Date: Dec 2008 Location: Italia
Member: 921682 Status: Offline Thanks Meter: 11 | I need solution for s6 g920f not detected by pc, always replaced flex charging connector equal, controlled zxw I found resistance from 2.2 ohms on scheme (r8022) not operating replaced but nothing, replaced still u7015 problem, I have already done also reset, always the same, help |
04-30-2017, 19:58 | #71 (permalink) | |
No Life Poster Join Date: Oct 2002
Member: 16943 Status: Offline Thanks Meter: 35 | Quote:
i need the battery ways too because i need to test the current consumition and i need to know the battery conector positive and negative terminals. thanks | |
05-02-2017, 02:40 | #72 (permalink) | |
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung sm-G920F battery connector ways | |
The Following 3 Users Say Thank You to d-Artigo For This Useful Post: |
05-04-2017, 22:19 | #73 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422282 Status: Offline Thanks Meter: 23 | I got s6. Phone was water damaged. It was showing triangle warning sign while on charge. Now it doesn't show that sign bt now it doesnt charge when battery is dead . It also doesnt charge when battery phone is powered on. N also consume battery really quickly. All symptoms are like iphone u2 ic. Dont know what to do! Pls suggest something Sent from my iPhone using Tapatalk Sent from my iPhone using Tapatalk |
