06-04-2017, 00:30 | #78 (permalink) |
Crazy Poster Join Date: Dec 2008 Location: Italia
Member: 921682 Status: Offline Thanks Meter: 11 | My solution is valid only if you always have the same problem by also replacing the full flat cable connector. Make sure the spare is working If it does not work, check the 2 resistors near, try jumping |
06-13-2017, 01:44 | #80 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422282 Status: Offline Thanks Meter: 23 | Hi, i got g920f , phone was water demage , manage to turn on the phone but now it shows only serial number , there is no imei and basband is unknown. I tried many flash files but result is still same , any suggestion pls? Sent from my iPad using Tapatalk |
08-02-2017, 13:35 | #81 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2743293 Status: Offline Thanks Meter: 0 | Galaxy S6 Edge sm-g925f problem during call. I have a galaxy S6 Edge sm925f when I use a Viber app to calling no problem in sound, but when i use sim card to calling no sound in microphone, Please help how I can fix. |
08-02-2017, 13:47 | #82 (permalink) |
08-09-2017, 23:26 | #84 (permalink) | |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | Quote:
after i remove diodes, what next bro? Have one thats not connect to the pc. "usb nor recognize problem" | |
08-22-2017, 07:50 | #85 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Padinharangadi,Kerala
Member: 1988081 Status: Offline Sonork: 100.1627039 Thanks Meter: 63 | https://ibb.co/eXUZp5 https://ibb.co/juzvwk https://ibb.co/haFJGk samsung g920f device over heating shows....need solution pls help me |
09-04-2017, 19:41 | #90 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685921 Status: Offline Thanks Meter: 5 | I have samsung sm g920i the phone is dead at present when i plugged a charger then simaltaneously u8006 gets heated up please help what to do as soon as possible i'll be highly thankful |
The Following User Says Thank You to Singhiskingh04@ For This Useful Post: |
