09-04-2017, 21:41 | #91 (permalink) |
Registered User Join Date: Aug 2007 Location: United Kingdom
Member: 567838 Status: Offline Thanks Meter: 64 | G920F - S6 no audio sound only from headphones There is no audio sound from speaker , changed Speaker but no sound Sound only working from headphones Please can someone advise on how to fix Kind regards |
09-05-2017, 01:58 | #92 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | Quote:
check its speaker path one by one ( see page 1 # 2 ) rehot or replace its U8002 ic audio amplifier (its located under ic audio codec) | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
09-05-2017, 02:32 | #93 (permalink) | |
check his handset shorting ??? (hit the water or fall) hot audio ic .. check the work teams in L8000 and C8001 try to lift both these components and measure whether the shorting is lost if not replace its ic audio U8006 | |
09-05-2017, 04:51 | #94 (permalink) |
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | samsung galaxy S6 sm-G920F gyro sensor problem first check its gyro sensor working voltage path rehot or replace ic gyro U4015 |
09-08-2017, 20:44 | #95 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2685921 Status: Offline Thanks Meter: 5 | I have samsung g920i the phone is dead and when we plug charger the u8006 gets heat what to do now replacing u8006 is the only solution or rehot is the availaible option board condition is fresh no water marks plz reply as soon as possible it would be a great help |
10-10-2017, 19:56 | #97 (permalink) |
Junior Member Join Date: Sep 2017 Location: Ukraine
Member: 2759968 Status: Offline Thanks Meter: 0 | Guys, maybe anybody knows, is there any probability to burn new replacement LCD module when trying to check if the board is OK? My waterdamaged G920F turns on, boots ok, connects to PC, but some time ago there were a few 100-200 pixels working on LCD, and then it turned all black. Now I need to know if I can safely connect new LCD module. The trouble shooting/repair guide says to check some voltages when display is activated on, but how can I get to according caps to measure when LCD connector almost fully covers them (C9016,C9020, C9019) and I have no access for probes? Or is it assumed when my LCD is disconnected, just push power or home button to just activate screen and take my measurements? PS seems to be I cannot post attachements, cant understand why I get "download failed". Any suggestions? Last edited by someo; 10-10-2017 at 20:06. |
10-18-2017, 20:08 | #98 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2697662 Status: Offline Thanks Meter: 0 | hi please help me I have a samsung s6 edge mobile. After the restoration activated samsung activation Id but my phone not respond data cable I change the chrging cable step but not response OTG cable not responc any one help me pleasewee |
02-06-2018, 13:07 | #102 (permalink) |
Junior Member Join Date: Feb 2018 Location: Belgium
Member: 2806509 Status: Offline Thanks Meter: 0 | Hello guys, looking for some help with this one... Galaxy S6 sm-g920f, drop in water. Battery was dead and change for brand new. Strange behavior when plug : charging but battery goes up and down showing 3 hours remaining, then 45 minutes then 2 hours and so on... I try to reheat like says in the "charging way" but no luck. I don't know what components are involve in the charging path. I also have a spare ldu for spare parts. If you have any ideas, you're welcome. Thanks in advance ! |
