01-08-2017, 21:36 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2670308 Status: Offline Thanks Meter: 0 | Samsung Galaxy S6edge Plus no Power solution Best Regards Boujay Germany |
01-09-2017, 13:44 | #2 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Hi if nothing happens from p.supply normally problem is big power ic in your case " S2mpb02 Power Manager IC " , but personally i would ceck still caps around power ic if short.. i repaired recently a g925f totally dead replacing power ic. good luck |
The Following User Says Thank You to orx For This Useful Post: |
01-09-2017, 14:14 | #3 (permalink) |
Member: 2670308 Status: Offline Thanks Meter: 0 | Hi orx, thank you , I will try again all the capacitors around the IC, then I will replace the power ic, I hope it is the power ic, not that I lose my time because of it. Thanks again. |
