09-20-2011, 09:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 997544 Status: Offline Thanks Meter: 71 | samsung galaxy tab p1000 no power solution i have a galaxy tab phone is not getting on i check near battery terminal its shows as a double side short.......plzzz help mi.., thank you.. |
10-02-2011, 13:54 | #3 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 176003 Status: Offline Sonork: bb pin 27883543 Thanks Meter: 74 | i had a galaxy tab client used it till the phone switched off,so i just replaced the batterry and reloaded software or you could boost the clients battery witha power supply i set it to 8v i the put it on the blac and red leads on the battery{wile the battery was disconnected} i constantly checked the battery voltage with the multimetre till the battery voltege was 3.6v then the phone should switch on. |
10-02-2011, 14:22 | #4 (permalink) | |
Freak Poster Join Date: Jun 2008
Member: 796514 Status: Offline Sonork: 100.1583845 Thanks Meter: 53 | Quote:
Must be hardware problem not software. Check if power ic short , if yes than replace it. thanks | |
11-21-2012, 03:12 | #9 (permalink) |
Junior Member Join Date: Jul 2011 Location: secret
Member: 1612766 Status: Offline Thanks Meter: 1 | i have the same problem here.... the history of the tablet is hard power on when i plug it in my p.c it suddenly went double shorted the positive is now negative andthe neagative is positiveand when you put a charger it turns very hot on the upper part of the charging pin of nthe tab... |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
