04-04-2014, 16:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17362 Status: Offline Thanks Meter: 242 | ▀▄► Samsung GT-i9500 - charging paused battery temperature too low - HELP ◄▄▀ Has " charging paused battery temperature too low" I did the following; 1. I replaced the entire USB charging flex assembly ribbon 2. Master reset & Clear cache 3. Upgraded phone via kies 4. New Battery 5. New Charger and still I have this problem... When I go to the Volume Up + Home + Pwr Android system recovery7 <3e> KOT495H.I9500UBUFNB3 Volume up/down to move Highlight; Power button to select reboot system now apply update ADB apply update from external storage wipe data/factory reset <--------- done wipe cache partition <----------- done apply update from cache --------------------------------- and a picture of Little android is an error "dead" " !" but the phone works fine, but wont charge every charger gives that error... Android 4.4.2 Baseband - I9500UBUFNA2 Kernel Version : 3.4.5-742022 build: KOT49H.I9500UBUFNB3 |
09-16-2014, 11:34 | #6 (permalink) |
Junior Member Join Date: Jun 2014 Location: Türkiye İstanbul
Member: 2206614 Status: Offline Thanks Meter: 2 | Hello First clean main board with thinner and brush, after resolder battery connector. |
The Following User Says Thank You to kutlusancak For This Useful Post: |
