10-14-2013, 11:11 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,629 | Quote:
samsung gt-i9505 not charging try to check L911 and C908 if both components are still working well replace U903 and U906 see the picture below only thank button | |
The Following 3 Users Say Thank You to d-Artigo For This Useful Post: |
02-01-2014, 13:34 | #6 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | I have a similar problem, with an S4 that was badly dropped on the floor. No shorts anywhere, and when i connect power on battery terminals, consumption is 0.00A , but if i try to power it up.. i have high consumption (over 1A) and phone doesn't power up. It also doesn't charge when connecting usb cable. Already desoldered, reballed and resoldered U903 without success.. |
02-01-2014, 15:49 | #7 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Quote:
Check the U501 output voltage - C835=1.225V, C838=1.05V. If the output voltage is not satisfied with normal condition, replace U800. Last edited by KorAll; 02-01-2014 at 15:57. | |
The Following User Says Thank You to KorAll For This Useful Post: |
02-01-2014, 15:59 | #9 (permalink) | |
Member: 1873863 Status: Offline Thanks Meter: 67 | Quote:
I found my problem !! :-) There was a short on VREG_S4_1P8 , two capacitors near UPC600 where shorted. C602 and C603. After removing those caps, no more short ! | |
The Following User Says Thank You to laptopmd For This Useful Post: |
10-28-2014, 16:18 | #11 (permalink) |
Junior Member Join Date: Aug 2012 Location: sarajevo, Bosnia and herzegovi
Member: 1795354 Status: Offline Thanks Meter: 2 | i9505 freeze on charging Hi all, I have Samsung Galaxy S4 with rather strange behaveour. Its original motherboard got fried during the charging process. So I looked around and found used Samsung Galaxy S4 i9505 with broken screen. its motherboard was from i9505. So when I ordered and replaced the motherboard the phone started behaving rather strangely... It boots normaly, and everithyng works when booted - GSM, WIFI and Blue Tooth. Normaly recognised by PC when connected using the USB cable. But when I connect the battery charger it starts behaving rather strangely. At first it starts charging (red led appears in top-left corner), and eventually (after say 15-20 minutes) it goes into "sleep mode" (black screen). If it remanins charging for 30 minutes or more it gets stuck - no buttons function, and the only way is to remove the battery and put it back after 10-20 seconds. More over, when it gets frozen it stops charging the battery. So please, Please anyone/everyone, HELP! Are there some motherboard components I should check out? |
11-01-2014, 12:24 | #12 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2284868 Status: Offline Thanks Meter: 0 | Quote:
i`m interested to know how u found that the short was in VREG_S4_1P8, plz i need ur reply soon cuz i`m facing such problems and i`m not able to find the short location... thanks | |
04-08-2015, 21:15 | #13 (permalink) |
No Life Poster Join Date: Oct 2009 Location: attock Age: 35
Member: 1147735 Status: Offline Thanks Meter: 156 | hi dear all master i have face a problem i9515 the problem is when i power on phone if power supply vol=4.5 just 0.4 imp and not power on still 0.4 imp after release power button i check Near U800 c835 and c838 no short equal value i also check OSC800 i have lot of search forum and many JTAJ option but my phone not power on may be i think my problem ON NEAR BATTERY TERMINAL PLZ CHECK MY REAL PHONE PIC ON HERE PIC 1.... AND PIC 2... VERY THANKS FOR ALL MASTERS BEST REGARD: WAQAS NADEEM |
07-08-2016, 03:10 | #14 (permalink) | |
Junior Member Join Date: Jan 2008
Member: 690040 Status: Offline Thanks Meter: 0 | Quote:
I was wondering if you solved this issue because I,m facing the same. So please inform me if there is any fix for this issue. Thanks | |
