10-04-2012, 10:36 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 45
Member: 183397 Status: Offline Thanks Meter: 23 | Samsung i9100 - S2 auto power on, cannot charge Some One se this problem in the i9100, when i connect the battery the phone power on like charge, and have Warning sign HOW CAN I SLOVE THIS PROBLEM. i try a lot of usb+flat connector, and another battery... and clean the board... who know ???!!!!! |
The Following User Says Thank You to sharbel For This Useful Post: |
10-05-2012, 09:50 | #4 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Kayamkulam,Kerala,India Age: 34
Member: 1434825 Status: Offline Thanks Meter: 6 | Disassemble the phone and disconnect the charging jack strip from the main board then insert battery and check .If still havin issue its an issue with the battery temperature detection . If phone powers on dial *#0228# and check batt temp could be around 35 deg cel .If its havin extreme variation must check VBAT line and BSI line for any damaged component .. Gud Luk Br . MONISH |
The Following User Says Thank You to monishkylm For This Useful Post: |
10-05-2012, 20:24 | #5 (permalink) | |
Member: 183397 Status: Offline Thanks Meter: 23 | Quote:
thank you i will try... and pst resolts | |
09-19-2013, 15:48 | #7 (permalink) |
No Life Poster Join Date: Feb 2003
Member: 21987 Status: Offline Thanks Meter: 27 | The solution! http://forum.gsmhosting.com/vbb/f258...-warm-1714227/ |
