10-11-2012, 10:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Sheffield
Member: 9372 Status: Offline Thanks Meter: 10 | Samsung i9100 Starts charging then says battery disconnected Samsung i9100 Starts charging then says battery disconnected, i have changed the dock connector and still the same. I have doner a few of these now without a problem but need a bit of help on this one any ideas people many thanks mRC |
01-26-2014, 18:04 | #7 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1469561 Status: Offline Thanks Meter: 6 | Battery disconnected Hi any solution to this problem? Battery is OK for sure. Replaced U503 (Charger control) due to dead by water damage - now battery disconnected after 1 second of plugging charger/USB. any ideas please ?! (it's already been a year...) |
01-26-2014, 18:21 | #8 (permalink) |
Member: 1469561 Status: Offline Thanks Meter: 6 | Battery Disconnected I9100 The phone was back from dead upon replacing U503 (Charging IC). Since then there was a "High or Low Battery Temperature" message when plugging charger/USB cord and immidiately "Battery Disconnected". I fixed the Temp issue with 39K fixed resistor instead of TH401. But now still remain with "Battery Disconnected" when plugged... When phone is off and plugged I get the yellow triangle with Battery sign striked through (see pic attached) Please any help appreciated! |
01-26-2014, 18:25 | #9 (permalink) |
Member: 1469561 Status: Offline Thanks Meter: 6 | not charging "Battery Disconnected" upon plugging charger/USB plug to I9100 Attached is the yellow triangle sign of "Battery Disconnected" (although battery is fine) and phone won't charge! Which circuit deals with sensing the battery presence? Samsung Galaxy SII I9100 (SGSII): |
01-26-2014, 18:26 | #10 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Philippines
Member: 1813688 Status: Offline Sonork: Davidlab Thanks Meter: 39 | salut.poti help me and I have a Samsung Galaxy S Plus I9001 I short the battery starts charging when the bag alone now but not loading |
07-31-2014, 15:23 | #12 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1617082 Status: Offline Sonork: [email protected] Thanks Meter: 0 | charge battery ok .. . |
08-01-2014, 18:15 | #14 (permalink) |
Member: 1469561 Status: Offline Thanks Meter: 6 | Battery Disconnected fault Like mRC said, there is no issue with the battery (I replaced it several times)... Which IC or pin schematic controls the BAT presence ? Still waiting for solution. |
