Samsung I9300 - No audio during calls Galaxy S3 I9300 No audio during calls ( no mic,receiver,speaker and headset).Can make and receive calls.Ringer is also working. But it works fine when using skype and fring. reason:used skype call and left it idle and when the gsm call received, audio went off. hard reset--- not recovered flashed with odin different firmwares--not recovered flashed custom rom C9-------not recovered updated to jelly bean 4.1.1----not recovered replaced headset jack-------not recovered flashed with SPT box I9300XXALEF---- lost network (only circle) repaired imei and unlocked in SPT-----S/N-00000000,"not registered on network" What may be the solution.Is it hardware or software issue. Any idea will be appreciated. sajidmirza |
i have the same problem with you but no luck until now there are no solution. |
Today i get same prb i m searching difrent Fourm some one say flash some one say hardwear I do all same like u but same problem even root or update Reset everything but same problem |
me too,, i have the same problem,,, sooo what the solution,,,, |
i had a phone with similar problem and only a flash with latest firmware on ODIN fixed it.. WBR Syed |
plss help us |
try flash with any version but for repair imei use octopus even with 4.1.1 workıng perfect :) |
I also have 3 pieces with no audio ,and I already tryed a lot of software versions and still the same I'm start thinking hardware.................... any clue?? best regards linterna1 |
same problem here.. have 3 pcs no audio during call any solution ??? |
hi everyone.i worked hard and i found solutions for audio problem in during calls i9300.it s a hardware problem.i will reply pm .thanks.. |
thanks in advance |
this is solution:) http://imageshack.us/photo/my-images/231/16223702.png/ |
1 Attachment(s) sorry guys.some problem with sharing photo.i added to attachement. |
this ic is glued....its risky unless u r sure it is the right solution |
