12-01-2012, 15:39 | #18 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | dear all open your phone and remove charging base connector and check head set working or not, if yes then replace charging flex. best regards. |
12-01-2012, 15:43 | #19 (permalink) |
12-01-2012, 16:31 | #20 (permalink) |
Junior Member Join Date: Jul 2006
Member: 306828 Status: Offline Thanks Meter: 8 | guys you want solution.i shared solution.yes i know this ic with glue.but there is no another solutions.i repair 17 pcs s3 in 3 days.i said true.but if you want you flash another rom or repair efs.but don't forget.it s real solution.i didn'twant money or other things from you.i am only want to help you.i dont understand some people still say software is the solution.yes its true software is solution when software has a problem.who can repair hardware problem with software can you tell me? |
The Following 2 Users Say Thank You to djender For This Useful Post: |
12-01-2012, 16:44 | #21 (permalink) |
Member: 306828 Status: Offline Thanks Meter: 8 | and don't forget.samsung used very very soft glue.it s not too hard.only you must be a little carefully.thats all |
12-05-2012, 18:37 | #25 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2006 Location: Riyadh saudia
Member: 407564 Status: Offline Thanks Meter: 141 | brother i done its not ic or charging base its lcd problem so much copy lcd in market thats not orignal change orignal then working perfect |
12-09-2012, 23:05 | #26 (permalink) |
Crazy Poster Join Date: Apr 2005 Age: 54
Member: 141715 Status: Offline Thanks Meter: 3 | it's not flash problem, u pay flash-it with all flash in this world. the solution is, when in call, press the touch in left of the home botton ( that touch usually is not visible ), than u will see " Noise reduction off " |
12-10-2012, 01:53 | #27 (permalink) | |
Member: 407564 Status: Offline Thanks Meter: 141 | Quote:
its work some but check lcd its lcd problem in market so much copy lcd is not gud quality | |
01-07-2013, 21:35 | #28 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
what condition of phone after remove this ic..... mean phone is power on and working all other feature without ic...... thanks | |
01-08-2013, 00:27 | #29 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Turkey
Member: 1058593 Status: Offline Sonork: 100.1625725 Thanks Meter: 433 | here factory bulten for finish all sound problem https://hotfile.com/dl/187885240/c39...Audio.pdf.html |
02-20-2013, 18:43 | #30 (permalink) |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | i9300 no sound during the call.. solution hello guys, i was reading up all you guys have same problem with s3 no sound on call i had same problem but i fixed it by flashing with this firmware I9300XXELLA_I9300OXFELL1_I9300XXELLA_HOME.tar.md5 with nspro[email protected] |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
