Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 02-25-2013, 14:44   #31 (permalink)
Member: 201881
my solution
hard format the phone first and then before making any call got to call settings and there in advance call settings there is an option NOICE CONTROL. just deactivate the option
Old 03-13-2013, 14:33   #32 (permalink)
rafikmob's Avatar
Member: 79627
Thanks Meter: 18
Originally Posted by R3İS View Post
here factory bulten for finish all sound problem
https://hotfile.com/dl/187885240/c39...Audio.pdf.html
salam
are you tested this solution ser
Old 03-18-2013, 08:53   #33 (permalink)
Member: 1899191
Sonork: 100.1625109
Thanks Meter: 134
Originally Posted by sajidmirza View Post
Galaxy S3 I9300 No audio during calls ( no mic,receiver,speaker and headset).Can make and receive calls.Ringer is also working.
But it works fine when using skype and fring.
reason:used skype call and left it idle and when the gsm call received, audio went off.
hard reset--- not recovered
flashed with odin different firmwares--not recovered
flashed custom rom C9-------not recovered
updated to jelly bean 4.1.1----not recovered
replaced headset jack-------not recovered
flashed with SPT box I9300XXALEF---- lost network (only circle)
repaired imei and unlocked in SPT-----S/N-00000000,"not registered on network"
What may be the solution.Is it hardware or software issue.
Any idea will be appreciated.
sajidmirza
same problm with me but not find any solution... Z3X team help us
Old 03-18-2013, 10:14   #34 (permalink)
shachash's Avatar
Member: 51905
Thanks Meter: 41
here you have the solution for the "not registerd on network"
working like a charm just tryd it yesterday
yes now you can repair imei i9300 with original imei or not original imei: work netwo
thanks will be epriciated
Old 04-08-2013, 21:43   #35 (permalink)
Member: 858331
friend djender ur alright
thx to much i try ur solition phone ill be ok thx so much
Old 04-09-2013, 07:46   #36 (permalink)
tunjay-gsm's Avatar
Member: 338192
Sonork: 1678261
Thanks Meter: 155
Thumbs up U are super bro thx xxxxxxxxxxx
https://hotfile.com/dl/187885240/c39...audio.pdf.html
super u are king off hardware than u soo mach u are best
Old 04-22-2013, 01:49   #37 (permalink)
Member: 164613
Thanks Meter: 11
Originally Posted by djender View Post
guys you want solution.i shared solution.yes i know this ic with glue.but there is no another solutions.i repair 17 pcs s3 in 3 days.i said true.but if you want you flash another rom or repair efs.but don't forget.it s real solution.i didn'twant money or other things from you.i am only want to help you.i dont understand some people still say software is the solution.yes its true software is solution when software has a problem.who can repair hardware problem with software can you tell me?
Thank you very much!
Mine case only resold it, some cases must change U604.
Old 06-02-2013, 09:57   #38 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
hi i have S3 i9300 audio problem
i have change 604 ic after change imei null null
is it bcos of 604 ic problem or any other problem?
Old 06-29-2013, 19:11   #39 (permalink)
Member: 1286387
Sonork: Buns27
Thanks Meter: 5
Ur problem isa baseband IC at the back of the IC u changed....
Old 07-02-2013, 08:07   #40 (permalink)
Member: 809622
Thanks Meter: 4
thank u for ur suggestion worked for me and done 15 phone same problem bought from singapore
Old 07-10-2013, 11:13   #41 (permalink)
Member: 1853027
just for the record:
i have the same problem with i9300 no sound during call no buzzer sound only in call other side hearing my voice i try everytingh flashing,on/off noise reduction...
finaly i make wipe data reset..then all sound on phone working.
i hope that will help.
Old 08-02-2013, 10:16   #42 (permalink)
Member: 124496
Thanks Meter: 17
Old 08-08-2013, 09:51   #43 (permalink)
Member: 293758
Thanks Meter: 33
I have same problem No audio, no mic. How can I solved this big problem?
Old 08-09-2013, 16:32   #44 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 262
we need to change that IC or REBALL or just REHOT is enough??
Old 08-18-2013, 19:06   #45 (permalink)
sreeju007's Avatar
Member: 1490333
Sonork: 100.1646411
Thanks Meter: 36
Audio codec ic problem
My 6150 (5.23) No network after Flashing AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-31-2001 14:56
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
Nokia 6110 without net. couldnīt call 911 either! DennisT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-09-2000 11:37
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.39927 seconds with 9 queries
