07-02-2014, 17:04 | #3 (permalink) |
Freak Poster Join Date: Jun 2004 Location: POLAND & BELGIUM Age: 42
Member: 67785 Status: Offline Thanks Meter: 20 | ok have solution ic number 1 U1006 hall efect , without ic gsm working normal |
The Following 3 Users Say Thank You to Simlok For This Useful Post: |
03-04-2015, 23:18 | #6 (permalink) |
Junior Member Join Date: Mar 2010 Location: The Netherlands
Member: 1261251 Status: Offline Thanks Meter: 4 | hallo , i have the same problem but with my own fault caused since i forgot the provider antenna under the motherboard and pressed little hard to close the silver bezel then i noticed that it won't tightly set, then i have openend all again and seen that ic nr.1 is little broken from a side, tried to put solder etcc.. with no joy. i have a s3 motherboard and looked under microscope but no identical ic found, WHERE CAN I FIND AN IC if i don't have a nother old defective one. any body an idea where can i find or buy such IC please. thanks in advance |
03-05-2015, 21:16 | #7 (permalink) |
Member: 1261251 Status: Offline Thanks Meter: 4 | i found it on dockconnctor of s5 , Colombo searching hahaha but will 1st buy a dock connector then take it off ... thanks inspite of no answer.. regards |
03-08-2015, 00:08 | #8 (permalink) |
Member: 1261251 Status: Offline Thanks Meter: 4 | just to put the result, today received the samsung 5s dock connector , and took off the Hall sensor ic, and put it on the s4 motherboard and telepone working great again without any problems . thanks |
02-26-2016, 23:19 | #13 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | it's not fake solution . i confirm , i replace magn. sensor U205 and i solve issue stuck in the flip cover thanks Artigo |
The Following User Says Thank You to orx For This Useful Post: |
