04-17-2015, 00:26 | #61 (permalink) | |
Junior Member Join Date: Aug 2006
Member: 333000 Status: Offline Thanks Meter: 0 | Quote:
I don't currently have an S4 board suffering from the "no sim" issue, so I can't try the fix, but it doesn't sound right to me. | |
05-08-2015, 22:12 | #62 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2077936 Status: Offline Thanks Meter: 21 | The U204 is the Broadcom 20794S1A standalone NFC chip underneath the sim tray flex and emi heat shield. Look at the picture of Step 15: https://www.ifixit.com/Teardown/Sams...Teardown/13947 |
05-15-2015, 03:57 | #63 (permalink) | |
Freak Poster Join Date: Oct 2011
Member: 1678566 Status: Offline Thanks Meter: 16 | Quote:
05-17-2015, 22:05 | #66 (permalink) |
Member: 1678566 Status: Offline Thanks Meter: 16 | Are you sure its that IC or that Broadcom Chip and not the sim card connector instead? Basically what is in the white box? I reflowed both those ICs and Broadcom chip and had the same error. Then on some forum a few people put tape on the Sim card connector so there was more pressure on the connector and the error went away, so I reflowed the Sim card connector and the problem seems to have gone away. When you reflow that IC chip its very close to the sim card connector and thats why it works. I looked under a magnifining glass and didn't see any of the pins broken but maybe they were nano cracks and a small reflow fixed the issue. Because those ICs and Broadcom chip have nothing to do with the sim card. |
05-25-2015, 16:19 | #68 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You are wrong ... this ( reflow near to flash diode ) work just because is on baseband ic MDM9215 ... the SIM is handled by modem part |
05-31-2015, 03:44 | #70 (permalink) |
Member: 1678566 Status: Offline Thanks Meter: 16 | LOL! I think you are all wrong and its the sim card+sd card connector that needs to be reflowed. Basically what is in the WHITE RECTANGLE in the above photo. In other threads people solved their issue by adding tape to apply pressure on that connector. I reflowed that connector and it solved the problem. Before I reflowed both the IC and the Broadcom NFC chip and didn't fix the error. Why it works when you reflow the IC or the NFC Chip is because its very close to the Sim card connector pins which reflow at lower heat because they aren't surface mount but exposed. |
The Following User Says Thank You to adaseb For This Useful Post: |
06-15-2015, 11:07 | #71 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Romania Age: 49
Member: 41105 Status: Offline Thanks Meter: 43 | hi all i read 7 pages of how heat the near sim chip from sim reader connector.........totally wrong the sim chip or driver or call how you like is QUALCOMM MDM9215m acordig to schematics.... other forum user says with a litle presure disipear insert sim problem.... now i use a microscope and big surprise .....on the other size of the litel black chip what all heating is the QUALCOMM MDM9215M chip, more exactly 2 Capacitor (near QUALCOMM MDM9215M)...see in the picture... what was unsoldered.... I us weller rework station and i fix this desoldered capacitors...now no more insert sim problem ... enjoy |
The Following 6 Users Say Thank You to kuli For This Useful Post: |
06-16-2015, 12:55 | #72 (permalink) | |
Junior Member Join Date: Jul 2011
Member: 1617846 Status: Offline Thanks Meter: 0 | Quote:
06-26-2015, 15:44 | #74 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Ireland
Member: 397374 Status: Offline Thanks Meter: 26 | Quote:
The Following User Says Thank You to okrongly For This Useful Post: |
