03-08-2015, 23:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: algeria
Member: 228703 Status: Offline Thanks Meter: 21 | need P5210 P5200 charge ways and solutions needP5210 P5200 charge ways and solutions change connector and flex but no solution in manuel diagrame Charging Part TA / USB Insert Yes Charging Sequence Start V_BUS = 5V No Check C5005 = 5V, or may not connected TA / USB Yes Battery is Charging? No Resolder or Replace U5005 END need jump please thx in advance |
06-08-2017, 17:28 | #3 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2725100 Status: Offline Thanks Meter: 3 | me too i have the same problem i Checked C5005 = 5V, its ok i try solution (reved battery and charge it in extern ) not solved i think is U5005 problem anyone have solution share plz |
06-11-2017, 12:51 | #5 (permalink) |
Member: 2725100 Status: Offline Thanks Meter: 3 | thanks for ur answer i do yes .. i rehot u5005 but no solved i cant find ic for replace the tablet does not turn on without battery ? ?? because the tablet is dead and when I plut 5v in the connector battery nothing also happens .. dont turn on That's why I'm trying to fix the charge thx for ur help |
