09-03-2015, 18:56 | #1 (permalink) |
Insane Poster Join Date: Mar 2013
Member: 1909191 Status: Offline Thanks Meter: 3 | samsung note 2 gt-n7100 dead. Not recognized by pc I have a samsung note 2 dead . It was charging the battery and fell . Glass damaged and the battery is coming out . Now No led , no sound . Not recognized by PC. I inserted jig , battery recharged externally , but Odin does not recognize it . Test with SD Card ( bbotloader of S3 as topic of this forum ) , shorted R319 , inserted battery and jig . I do not see anything on the display ( perhaps it is damaged as glass ) , nor it is recognized by pc kies or odin . There may be a short circuit on the motherboard next to the flat of the charging connector ? With jig inserted heats the part of the SIM card and SD card . Who will help me in the test and measurement ? I have a digital multimeter , no box or regulated power supply . Thank you. Those who follow me step by step ? |
The Following User Says Thank You to bollicine For This Useful Post: |
09-05-2015, 11:56 | #3 (permalink) |
Member: 1909191 Status: Offline Thanks Meter: 3 | please help me!! A question: in youtube's video the man ago a short circuit with a tweezer but the resistance isn't R319. What's and why he does after changing the EMMC? Does anyone know answer? here link of video http://www.youtube.com/watch?v=HdMmXT5gn7A&sns=em thanks for help! I'd like to understand the problem on my samsung note if you can help me.... to look for a short circuit! I don't know and I'm not so good! it might be the resistance marked in the picture? with multimeter, in test diode, the resistance sounds! what does it mean? |
01-17-2016, 17:52 | #5 (permalink) |
No Life Poster Join Date: Jan 2013 Location: lebanon
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | Check u500 output on this capacitors Check and Mesure coils on buzzer mode if cracked and replace Check and Mesure capacitors if shorted or cracked and replace |
01-17-2016, 18:50 | #7 (permalink) |
Member: 1869842 Status: Offline Sonork: 100.1625473 Thanks Meter: 186 | No need to connect USB cable It's the exactly location of capacitors Check voltage on them like schematic show while keep pressing power key If there is a different in voltage mesuring on capacitors then the problem is from the u500 ic and you need to change it If voltage mesuring on capacitors is right like schematic show Mesure this capacitors on buzzer mode out of circuit |
