Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-08-2016, 15:55   #1 (permalink)
Member: 2606933
Thanks Meter: 2
Samsung j5- back button, pls help.!!
Hii
Samsung j-5 back and menu button not working, i try new fleks but not working. Home button its work. the device also had water damage, after cleaned device work but just back-menu button not working.
I think problem motherboard, but i dont now how to solution. Help plzz
The Following User Says Thank You to egehan42 For This Useful Post:
Old 09-09-2016, 04:55   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,629
Originally Posted by egehan42 View Post
Hii
samsung sm-j500h back button problem
rehot or new locker ic touch key regulator U5001
See the picture below
The Following 14 Users Say Thank You to d-Artigo For This Useful Post:
Old 09-09-2016, 06:11   #3 (permalink)
Member: 2080580
Thanks Meter: 42
good work dear.............
keep it up .........it works 100% i tried it ..............
The Following 2 Users Say Thank You to tarique ali For This Useful Post:
Old 09-09-2016, 17:28   #4 (permalink)
Member: 2606933
Thanks Meter: 2
Thnks for reply, I think the problem IC U5001.
now i removed IC u5001, but all the ways damaged. How to jumper plz ?
Old 12-21-2016, 16:58   #5 (permalink)
Member: 2638659
Sonork: www.sonork.com
pls ways
pls ways back button.......
Old 12-26-2016, 14:32   #6 (permalink)
Member: 2274875
Sonork: ?
Thanks Meter: 298
just back button software ... for temporay.. sloved
The Following User Says Thank You to the boss atik For This Useful Post:
Old 01-16-2017, 12:42   #7 (permalink)
Member: 307235
Thanks Meter: 10
how to jumper please........
The Following User Says Thank You to gop3l For This Useful Post:
Old 04-13-2017, 09:00   #8 (permalink)
Member: 264667
Sonork: 100.105892
Thanks Meter: 481
I have same problem i change the ic.but same position.menu back and option touch keypad not working
i check the flex works perfact
The Following 2 Users Say Thank You to ..::AppleLinks::.. For This Useful Post:
Old 04-20-2017, 16:56   #9 (permalink)
ozeltekno's Avatar
Member: 754364
Thanks Meter: 59
j5 touch jumper solution ,Paths and schema ?
The Following User Says Thank You to ozeltekno For This Useful Post:
Old 05-10-2017, 18:46   #10 (permalink)
tekirdaggsm's Avatar
Member: 106391
Thanks Meter: 37
if not works i tested %100 working
The Following 6 Users Say Thank You to tekirdaggsm For This Useful Post:
Old 07-22-2017, 12:42   #11 (permalink)
Member: 622934
Thanks Meter: 46
try this one...
Attachment 357554
https://www.4shared.com/photo/l4p22zBpei/IMG_0176.html
The Following 3 Users Say Thank You to londangsm For This Useful Post:
Old 10-13-2017, 09:17   #12 (permalink)
Registered User
Member: 1077541
Thanks Meter: 77
https://www.youtube.com/watch?v=mI9I...ture=********* try this
The Following 2 Users Say Thank You to saman kumara For This Useful Post:
Old 10-13-2017, 14:05   #13 (permalink)
Member: 2559111
dear friends did anyone knows where is the touch ic on j5 2015? i have 2 j500 with water damage and the lcds and the touch works but the logic boards have problems.
the screen works, but i have no touch?? any help please?
thanks for advance
The Following User Says Thank You to dgeo021 For This Useful Post:
Old 02-16-2018, 10:56   #14 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
Hii
try this 100000% done
https://www.facebook.com/profile.php...bhZOajHnoyAng8
wbr
IMRAN KHAN JODHPUR
The Following User Says Thank You to imrankhan0143 For This Useful Post:
Old 03-22-2018, 08:26   #15 (permalink)
Member: 1312979
Thanks Meter: 2
Hii
Samsung j-7 <j700h> back and menu button not working, i try new fleks but not working. Home button its work. the device also had water damage, after cleaned device work but just back-menu button not working.
The Following User Says Thank You to Bajrabarahi For This Useful Post:
Page generated in 0.19429 seconds with 9 queries
